DIY LED Corner Reflectors
Old Mar 31, 2009 | 09:19 AM
  #101
tight350z's Avatar
tight350z
my home made 06+ LED reflectors!
Old Apr 2, 2009 | 12:39 PM
  #102
hanzie411's Avatar
hanzie411
would these work on the parking lights?
Color Red WLED-R6Amber WLED-A6Cool White WLED-CW6 (+ $0.95)Natural White WLED-NW6 (+ $0.95)Warm White WLED-WW6 (+ $0.95)Blue WLED-B6 (+ $0.75)Green WLED-G6 (+ $1.15)UV-BlackLight WLED-UV6 (+ $0.95)
WLED-x6 LED bulb
12 VDC 6-LED Wedge Base bulb (194/168 type)
With built-in voltage regulator
Select LED Color
$ 2.79
Check Out
Old Jul 6, 2009 | 09:05 PM
  #103
chaparro78's Avatar
chaparro78
my version. I used 7 super bright red LEDs
Old Jul 7, 2009 | 03:34 AM
  #104
carnutfl's Avatar
carnutfl
Just watch it around cops. There are laws against red lights facing forward.
Old Jul 13, 2009 | 04:12 AM
  #105
Kiriller's Avatar
Kiriller
Did mine few months ago, used the right resistors and the right amount of leds, problem is that they all died out. the hell did i do wrong... (dont think its because i wired it up to the drl)
Old Jul 22, 2009 | 11:53 AM
  #106
tight350z's Avatar
tight350z
on both sides or just one side? usually if one fails in a series they all fail..
Old Jul 30, 2009 | 06:12 AM
  #107
Pawel's Avatar
Pawel
I did this mod. I used 3 LED and resistors(560 ohm) pairs per reflector.
Thanks for the write up.
Here's some pics...
Night shots...
Old Sep 2, 2009 | 07:34 AM
  #108
o2sys's Avatar
o2sys
For those who dont know which LED to order nor do they know how to solder them here is a pre-made LED bar DIY link:
http://g35driver.com/forums/body-int...rker-mode.html
I haven't done mine yet but this looks more straight forward. Just open up the or drill (however you like) your stock marker and put these LEDs and wire it up!
Old Nov 5, 2009 | 07:46 AM
  #109
copija123's Avatar
copija123
can someone post the links to where you got the clear side markers and the bright *** LEDS
Old Nov 5, 2009 | 07:49 AM
  #110
copija123's Avatar
copija123
Default parking light
Originally Posted by cspinner
I did this mod. Thanks for the write up. I decided to use 7 LED/resistor pairs per reflector, wired in parallel. The night shot didn't come out very well, since it made the LED's look blue. Anyway, I want to replace the parking light with something that doesn't look so yellow. Any thoughts? I love tinkering with this kind of stuff. If anyone wants to send me their reflectors, I'd be happy to do this.
check out my profile picture it i changed the parking light....
Old Apr 7, 2012 | 03:41 PM
  #111
island03z's Avatar
island03z
anyone know how i could make the entire reflector light up with one solid color insead of having little dots showing up?
Old Apr 10, 2012 | 09:33 AM
  #112
Deteria's Avatar
Deteria
Add more LEDs lol.
Old Apr 10, 2012 | 01:41 PM
  #113
dcains's Avatar
dcains
Someone on the board here made a set with ccfl's instead of LED's. It was in a thread from a few years back.
Old Apr 13, 2012 | 08:34 PM
  #114
island03z's Avatar
island03z
Yea i saw that thread but there was no diy or how to and I have no idea how to mount it where it would refract through the entire lens evenly. I'm trying to get the effect of the new chrysler 300's headlight where their daytime running light is LED but refracts really evenly.
Old Apr 13, 2012 | 10:22 PM
  #115
dcains's Avatar
dcains
My setup has 21 LED's per reflector, so unless you're very close, it looks like a continuous strip of light:
Old Apr 30, 2012 | 12:15 AM
  #116
wks2000's Avatar
wks2000
I did it too
Some pics.
Thanks Paul!
Attached Thumbnails DIY LED Corner Reflectors-img_20120430_011002.jpg   DIY LED Corner Reflectors-img_20120430_010916.jpg
Old Apr 30, 2012 | 09:17 PM
  #117
felixortiz's Avatar
felixortiz
Can you show me how you did it? Where to buy and what to buy?
Old Apr 30, 2012 | 10:19 PM
  #118
dcains's Avatar
dcains
I used these strips:
http://www.ledlightsworld.com/smd-50...eds-p-135.html
I bought two 1-foot sections and trimmed them to fit the reflectors. There are actually 24 LED's in each reflector, not 21 as I originally posted. I used the pure white, waterproof, white background.
These are the second set of reflectors I made. The first were a quick failure, after the LED strips I bought from oznium.com had multiple LED'S die after just a few weeks of minimal use. Here's what happened with the sh!tty oznium LED's, and there are lots like these sold on eBay, too:
Old May 1, 2012 | 04:14 AM
  #119
N8s93turbo's Avatar
N8s93turbo
Any method to trimming them?
Old May 1, 2012 | 08:11 AM
  #120
dcains's Avatar
dcains
Just a sharp razor blade. You can trim the LED's in multiples of 3. You could probably also order them in a 24-LED section (8"), if that's easier for you, but they're sold by the foot, which is 36 LED's. I glued everything with clear silicone.
