DIY: repairing faded/foggy headlights
Old Mar 24, 2009 | 07:27 PM
maXmood's Avatar
maXmood
Under Boost!
Default DIY: repairing faded/foggy headlights
searched through the forum, but couldn't find one. so i thought i'd share..
What you need:
-Sanding papers (1500 and 2000 grit).
-Zymol Cleaner Wax (or any wax/polish you trust to be good).
-Microfiber towel.
-A buffer (optional)
On with the (easy) process..
1- wash the headlights with water and soap then rinse it with a towel.
2- with water running over the headlight, start sanding (with light to no pressure) the foggy area (with 1500 grit) for at least 3 minutes. *make sure the headlight is always wet while sanding*
3- once you're done, do the same thing using the 2000 grit paper.
4- rinse the headlight and apply Zymol Wax (or the one you prefer). since i don't own a buffer, i used my fingers to spread the wax all over the sanded area. (wait for it till it dries *approx. 3-5mins*)
5- wipe the headlight with the microfiber towel.
wallaa, you should be done. but if need be, you might wanna have another go with the wax/polish to achieve a better result. tho applying it 10 times won't make it new
on with the pics.. (phone cam)
Before
After
Before
After
Old Mar 24, 2009 | 08:56 PM
AznKaos15's Avatar
AznKaos15
nice job but what you need is polish, not wax.
wax does not have any abbrassive properties and will only cover up the 2000 sanding scratches temporarily. your after pictures are still hazy.
get yourself some polish and a machine if you can and it will look brand new.
Old Mar 24, 2009 | 09:01 PM
maXmood's Avatar
maXmood
Under Boost!
^that what i was going to do..but at the time i didn't have anything but Zymol, so i thought i'd give it a try.
i'm getting Megs PlastX. i'll post updated pics once done.
Old Mar 24, 2009 | 09:28 PM
AstroZombie's Avatar
AstroZombie
WOW that Bahrain sun really cooked those lenses fast!
I love the plastX, it works really well. I find I need to reapply about every other month or so, but that may be because I'm picky...!
Good job on the sanding part, I had a set of '05 lights that were bad enough for wetsanding too.
Old Mar 24, 2009 | 09:46 PM
maXmood's Avatar
maXmood
Under Boost!
Tell me about it!! it reaches 50C (122F) degrees in summer.! and summer usually lasts 6 to 7 months a year.
so, the current ones were foggy too?? if so, then how about you share a pic of how PlastX treatment looks like?
thnx for the input
Old Mar 24, 2009 | 09:53 PM
AstroZombie
thnx for the input
HAHA, I was in Bahrain for a few days back in 2005, I would rather not experience that heat again!!!
I'll have to get pics of my lights tomorrow, Its dark here in CA right now.
Old Mar 25, 2009 | 09:23 PM
AstroZombie
Here are a few. Taken with my phone, don't mind the grainy pics.... or the splattered bugs
Attached Thumbnails DIY: repairing faded/foggy headlights-0325091203-00.jpg   DIY: repairing faded/foggy headlights-0325091204-00.jpg   DIY: repairing faded/foggy headlights-0325091934-00.jpg
Old Mar 26, 2009 | 03:02 AM
maXmood's Avatar
maXmood
Under Boost!
they look great imo.. tho you got some little swirls on first pic. why not try a little sanding job ?
btw, u painted those heads? or a shop did it for you?
Old Mar 26, 2009 | 03:21 AM
k6750gsxr's Avatar
k6750gsxr
3m makes a headlight restoration kit that works really well. My headlights were foggy and had left over glue from overlays and it cleaned them right up.
Old Mar 26, 2009 | 08:16 AM
AstroZombie
Word, yeah there are light swirls that you can see from certain angles and sunlight. I'm sure some 2000 grit will polish them up really nice.
I painted my lights and did the demon eye mod. Its fairly easy, the hardest part is getting the lens off, then back on and sealed correctly. Heres my DIY on adding the demon eye, and there are countless threads on how to black them out. Enjoy!
https://my350z.com/forum/body-interi...eadlights.html
Also, if you decide to blackout your headlights the lenses really need to be clean, every little speck will show up X10 once the lens is on a black background.
Old Mar 26, 2009 | 08:00 PM
rg1203's Avatar
rg1203
3m has a kit with 500 grit 800 grit and a 300 grit pad, come with 3m polishing compound and polishing pad, attach to a drill and your golden, i charge peeps 50 bux all the time around town, it works really well. i just did mine, i shoulda done a before and after
Old Mar 26, 2009 | 09:03 PM
mthreat's Avatar
mthreat
Where do you buy this 3M restoration kit you speek of?
Old Mar 28, 2009 | 02:57 AM
Phreakdout's Avatar
Phreakdout
Thumbs up
It took me about 35 seconds per side.
I was amazed how fast and good this works.
Old Mar 28, 2009 | 04:40 PM
maXmood's Avatar
maXmood
Under Boost!
we don't have all MOTHERS product lines in Bahrain.. sux..
^that power ball can be used with any drill?
Old Mar 31, 2009 | 08:02 PM
nassin_z053's Avatar
nassin_z053
nice job!
Old May 3, 2009 | 06:46 PM
gr8scott_o's Avatar
gr8scott_o
After painting headlight black, scratches become REALLY apparent. I tried Powerball and Mother's PowerPlastic today. Huge improvement, but I would say took care of 98% of the problem. Pics below:
Fig 1: Before Shot, Driver's Side.
Fig 2: Some prep work.
Fig 3: In progress... go easy with application of polish, as you can see once the powerball spins it will splatter. I found it best to apply a little to the ball, then rub it onto the surface of the headlight to spread it around first. Then spin up the drill slowly.
Fig 4: After buffing.
Fig 5: Close-up After shot. As you can see, some scratches are still apparent but very subdued. This was as good as I could get it, but unless you are this close you will not see it.
Fig 6: Passenger side appeared worse...
Fig 7: ...but cleaned up better. I would say 99% gone on this side.
Fig 8: Driver's side after in direct sun.
Fig 9: Passenger side after, direct sun.
Old May 4, 2009 | 03:42 AM
maXmood's Avatar
maXmood
Under Boost!
^that's WOW!
very good job!! i need to get PlastX soon, because my current application is washing away and fog is coming back.
btw, u did the black out urself?
Old May 4, 2009 | 06:40 AM
JMS71585's Avatar
JMS71585
Damn, these headlights look like they're brand new.
Are you guys saying to sand them down first, and then use Megs PlastX? My headlights are hazy and i've been looking to get rid of the haze...
Old May 4, 2009 | 10:44 AM
maXmood's Avatar
maXmood
Under Boost!
that's what i've done/will be doing.. but others suggest that u go with PlastX with a buffer *first*, and if it didn't work, then go with sanding and PlastX..
just go with 2000 grit sanding paper.. i noticed that 1500grit shaves off a little from that clear coat on the headlights. and make sure water is running while u're sanding (wet sanding).
tomorrow *hopefully*, i'll take pics of how do they look like after 1 month (since i started this thread), and other pics of redoing them again, but this time with PlastX and maybe a buffer..
Old May 4, 2009 | 04:09 PM
gr8scott_o's Avatar
gr8scott_o
^that's WOW!
Thanks! Yes, I did black them out myself.
