HOW TO: remove rear wiper
Old Nov 10, 2003 | 10:01 AM
the doc's Avatar
the doc
Default HOW TO: remove rear wiper
I decided to take off my rear wiper since I hardly ever use it, plus it breaks up the flow of the hatch. I bought a metal hole plug from Lowe's along with a 1" bolt. My plan was to use superglue, but that ended up not working.
Old Nov 10, 2003 | 10:02 AM
the doc's Avatar
the doc
When the superglue failed I decided to use JB Weld, 2500psi. I also cut the threaded end off of an eye bolt to use in the installation.
the doc's Avatar
the doc
To remove the wiper, lift up on this cap. After you remove this nut you should be able to pull up on the blade.
Old Nov 10, 2003 | 10:03 AM
the doc's Avatar
the doc
My blade would not budge after removing the nut. I thought it might need to be turned counter clockwise to loosen it, but that's when the shaft snapped off!
Old Nov 10, 2003 | 10:04 AM
the doc's Avatar
the doc
After removing the plasic cover from the hatch, you will see the motor. Remove the three bolts and unplug the white harness.
Old Nov 10, 2003 | 10:05 AM
the doc's Avatar
the doc
As you can see in this pic of the seal, when the top of the seal is flattened, the bottom bulges below the edges. This is why the eye of the eyebolt is needed to space the washer down.
the doc's Avatar
the doc
Here is the installed eye wedged between the seal and washer.
Old Nov 10, 2003 | 10:07 AM
the doc's Avatar
the doc
Finished product! The cap is painted and installed, it just needs to be waxed.
Old Nov 10, 2003 | 10:08 AM
the doc's Avatar
the doc
Last shot, close up. The whole rear end of the car seems to be much smoother and attractive without the wiper!
Questions/comments welcome!
Old Oct 10, 2006 | 04:37 PM
Nucleus's Avatar
Nucleus
Can You make these pics show up? All I see are the red X's.
Cant see S#!T Captain
Old Oct 10, 2006 | 11:41 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
These posts are from 2003. Good luck contacting the OP.
Old Oct 11, 2006 | 08:52 AM
Nucleus's Avatar
Nucleus
I did notice they were from 03. Oh well.
Old Oct 28, 2006 | 07:47 PM
350V's Avatar
350V
damn
Old Nov 12, 2006 | 07:37 PM
smokedout350z's Avatar
smokedout350z
he suk
Old Nov 13, 2006 | 03:12 PM
gimpster621's Avatar
gimpster621
people who did this alreay ya got pics? im thinking about doing this
Old Dec 14, 2006 | 05:28 PM
350ZEnthusiast's Avatar
350ZEnthusiast
Me too, please. (^+1)
Old Dec 14, 2006 | 05:34 PM
Jay'Z's Avatar
Jay'Z
there are plenty of pics.. do a search for rear wiper..... its in the first 5 pages.. Youll see plenty of pics and different ways of doing it..
Old Aug 22, 2008 | 09:34 AM
nasty350's Avatar
nasty350
good thread
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
