Titanium coloring....
Old Jul 28, 2010 | 02:02 PM
350zion's Avatar
350zion
Professional
Default Titanium coloring....
So im on vacation and me and my son where extremely bored outta our minds when I had this great idea? How about turning my titanium NISM0 shift **** into colored titanium like my exhaust? Sounds cool but has the makings of an epic failure. So off we go removing the shift **** and getting the torch outta the truck. Basically this is what i did:
How to produce the oxide layer and get the colors:
Heat. Titanium eagerly grabs oxygen from the air, but the oxide layer blocks slow moving oxygen from the surface. So, torch the surface gently to give the atoms the boost they need to charge through the dielectric barrier to bond together and build a thicker layer. It's a bit hard to control, but you can easily get the first-order colors (bronze, blues, maybe yellow). Higher-temperature / longer-time colors are much harder to get and control with heat.
taken from a random google search, in other words heat the surface from a distance starting at the point you want to be blue then work away from that area pulling away from the flame as you move away from your starting point. The colors are blue purple yellow start to finish respectively. Be careful once the titanium piece has turned blue because after that it can start to destroy the metal. You can get some pinks n greens outta it but after that u scorch the hell outta it, no fears tho if u screw up jus sand the piece down and start over. Its jus the oxidized layer that ur sanding off and the titanium will be down to a bare piece in no time. For more appeal polish the piece to have a chrome like finish first then hit it wit the flame. I used a standard plumbers torch but u can get the cheapo set up wit propane tank from home depot. That will be sufficient. As for my shift **** I didnt remove the plastic insert first or the shift pattern label from the top. I heated it up until I could take the shift pattern piece off the top which is glued on. Then melted the hell outta the plastic inside. ( mine was already beat on the inside so replacing it was bound to happen.) Then heat it and watch the magic happen. Now one thing is sure be careful not to drop it cause I dropped mine and put a serious nick in the top, again no problem jus wet sand out and youll be alright.
Attached Thumbnails Titanium coloring....-imag0021.jpg   Titanium coloring....-imag0022.jpg   Titanium coloring....-imag0030.jpg   Titanium coloring....-imag0036.jpg   Titanium coloring....-imag0040.jpg
Old Jul 28, 2010 | 02:20 PM
350zion's Avatar
350zion
Professional
Default Continuation
So heres the finished product but first some things had to be done about the melted plastic piece that threads it on to the shift lever so enter trusty JB weld epoxy.
Mix a large amount so u can fill the bottom of the shift **** use more hardener than the actual resin because IMO it hardens faster. Then tape off the piece so not to make a mess. Fill the hole and let dry. Drill out center with a smaller bit then ur shift lever so u can thread the **** on later. Now if someone knows where to get a replacement piece for the inside of the **** please feel free to post. I did mine the In a hurry way and made mistakes to show that things r forgiving and DIY can and should always be tackled no matter how unskilled a person is. If you fack it jus buy a new one... Thanks hope this was helpful, and BTW I searched the site and didnt find any one posting this. GL...
Attached Thumbnails Titanium coloring....-imag0057.jpg   Titanium coloring....-imag0071.jpg   Titanium coloring....-imag0080.jpg   Titanium coloring....-imag0084.jpg   Titanium coloring....-imag0087.jpg
350zion's Avatar
350zion
Professional
more pix soon I gotta go and this uploading dont be worky so well
Old Jul 28, 2010 | 04:21 PM
13ringinheat's Avatar
13ringinheat
great post and the results are pretty good IMO i like the DIY posts it gives people new ideas.
Old Jul 28, 2010 | 04:24 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
i did ages ago but thanks for the post
Old Jul 28, 2010 | 04:25 PM
zaperroni's Avatar
zaperroni
wow looks pretty nice for an at-home job...
i'm considering doing this for my exhaust tips
Old Jul 28, 2010 | 05:00 PM
huyrua's Avatar
huyrua
Make sure your exhaust tips are titanium to get the same result.
Old Jul 28, 2010 | 05:19 PM
Miggz's Avatar
Miggz
Nice job, and if I may add.. Nice Avatar!
Old Jul 28, 2010 | 05:27 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
pretty cool
jbaker1121's Avatar
jbaker1121
nicely done, my motordyne rolled Ti tips got ruined at a carwash because they sprayed wheel cleaner, so i was thinking about re-burning them myself..... nice write up
Old Jul 28, 2010 | 06:04 PM
glenns280's Avatar
glenns280
great job, an good to see father an son workin on cars...
Old Jul 28, 2010 | 08:37 PM
350zion's Avatar
350zion
Professional
Thanks all. Me and the boy were extremely bored I however took great pleasure in doin this my son ,,,, not so excited so now im lookin for other things I can burn... So if u plan on doin this make sure the piece ur doin is titanium first I wouldnt try this on chrome as it wont have the same outcome... Thanks again keep doin it urself ,and be proud of ur work no matter how shatty it looks....
Old Jul 29, 2010 | 06:37 AM
scotts300's Avatar
scotts300
Most exhaust tips that are Ti have already been oxidized for the cool factor. Make sure you double check.
Old Jul 29, 2010 | 06:42 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Awsome Avatar... Im actually considering doing it to my ARC strut tower brace.
Old Jul 29, 2010 | 07:49 AM
scotts300's Avatar
scotts300
Did you really pay ~$900 for the Ti version of that brace? Yikes!
Old Jul 29, 2010 | 08:50 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Awesome DIY! The nismo shift **** looks 10x better like that! Great Job!
Old Jul 29, 2010 | 11:20 AM
Flo-ridaZ33
Scott... I thought all of them are titanium? I bought off a member here for much less.
Old Jul 29, 2010 | 12:28 PM
scotts300's Avatar
scotts300
I believe they are, that asking price is insane.
Old Jul 29, 2010 | 12:37 PM
07_z33's Avatar
07_z33
You should. It looks 10x better
Old Jul 29, 2010 | 12:41 PM
RedBullRR's Avatar
RedBullRR
I cant focus with them boobies jumping up and down.
