DIY refurbish hatch lifters
Old Mar 6, 2016 | 12:02 PM
blufc3s's Avatar
blufc3s
Default DIY refurbish hatch lifters
This will probably be the easiest, quickest and cheapest repair you'll ever do.
To remove the lifter from the hatch you turn it 90' and pull out of the slot.
Take it to your work bench, remove the boot and insert pennies in the bottom of the boot as required to provide additional preload to the lifter.
Replace the lifter. Keep adding pennies as necessary.
I had to do this to mine as I added some sound deadener to my hatch and it wouldn't pop up,so you could lift it.
<a href="http://s638.photobucket.com/user/blufc3s/media/2007%20350Z/image.jpg1_1.jpg.html" target="_blank"><img src="http://i638.photobucket.com/albums/uu104/blufc3s/2007%20350Z/image.jpg1_1.jpg" border="0" alt=" photo image.jpg1_1.jpg"/></a>
Old Mar 6, 2016 | 12:32 PM
travlee's Avatar
travlee
Master
only works for a while, the center piece of the spring will eventually break..... just saying and my 2 cents
Old Mar 6, 2016 | 05:43 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
My car doesn't have those
Old Mar 7, 2016 | 02:52 AM
blufc3s's Avatar
blufc3s
Im surprised, both my 07 and 03 has them:
<a href="http://s638.photobucket.com/user/blufc3s/media/image_5.jpeg.html" target="_blank"><img src="http://i638.photobucket.com/albums/uu104/blufc3s/image_5.jpeg" border="0" alt=" photo image_5.jpeg"/></a>
Old Mar 7, 2016 | 03:01 PM
SirSpeedyZ's Avatar
SirSpeedyZ
I did this and it worked for awhile, doesn't anymore....
Old Mar 7, 2016 | 03:26 PM
mr. sparco's Avatar
mr. sparco
Mod back from the grave, I remember this, temporary bandage.
Old Mar 7, 2016 | 04:21 PM
turboed350z's Avatar
turboed350z
Pfft. I put nickles in mine cause im a baller.
Old Mar 7, 2016 | 04:41 PM
dboyzalter's Avatar
dboyzalter
I took mine off for weight savings. Every little bit helps on the race driver
Old Mar 8, 2016 | 02:31 AM
blufc3s's Avatar
blufc3s
Sorry, must have missed the original thread. Guess I will start saving up for some new lifters (heh heh).
Old Mar 8, 2016 | 03:13 AM
travlee's Avatar
travlee
Master
like i said, this works for a bit but puts extra pressure on the spring and it will eventually fail (think mine was like a year). they are expensive for what they are though
http://www.courtesyparts.com/nissan/...ft-gate-spring
Old Mar 14, 2016 | 06:02 AM
chuddly's Avatar
chuddly
Just curious if anyone has tried anything like these? They would provide extra push and its what they are meant to do. I dont think they would break as easy as the other either.
http://www.summitracing.com/parts/su...RWQaAvaF8P8HAQ
Chad
Old Mar 14, 2016 | 06:04 AM
travlee's Avatar
travlee
Master
i would worry that they are too deep, wouldnt want to bend the hatch up from the underside
Old Mar 14, 2016 | 06:38 AM
chuddly's Avatar
chuddly
I was thinking more of putting them on the body side and let them push up. they make flush mount ones also
Old Mar 14, 2016 | 06:51 AM
travlee's Avatar
travlee
Master
gotcha... they should work
Old Mar 17, 2016 | 01:42 PM
rustyschopshop's Avatar
rustyschopshop
haven't seen door poppers in a long time, i bet they would work nice with a metal stiker plate in place of the oEm craps
tjc6591
Apr 29, 2026 01:22 PM
go1f17
Mar 6, 2016 09:39 AM
BlueSpeakers
Feb 27, 2016 04:36 PM
