SPC Toe Bolt install write up with pics courtesy of Protocav.
Old 04-29-2008, 05:12 AM
  #101
BriGuyMax
Turbo Whore
BriGuyMax's Avatar
Originally Posted by pancho05tyco
so regardless of what year Z you have, you must elongate the slot?
Yes
Old 04-29-2008, 05:13 AM
  #102
BriGuyMax
Turbo Whore
BriGuyMax's Avatar
Originally Posted by minispider
subscribing
You don't need to post to subscribe. There's an option to subscribe and unsubscribe under "thread tools" at the top of each page.
Old 06-23-2008, 06:16 PM
  #103
Spoiled Z
Spoiled Z's Avatar
What if you dremelled tad bit more than what is require will the toe bolt slip?
Old 06-25-2008, 12:43 PM
  #104
BriGuyMax
Turbo Whore
BriGuyMax's Avatar
Shouldn't...unless you dremel A LOT more....
Old 07-01-2008, 02:13 PM
  #105
zzz350
zzz350's Avatar
Just installed my SPC camber arms and toe bolts in the rear, easy install, very good instructions to follow. the only thing missing was to remove the brackets holding the sway bar in place, other than that, not much to complain about.
Old 07-01-2008, 02:45 PM
  #106
Sublimal
Sublimal's Avatar
Installed mine over the weekend....the ***** was filing the toe holes...i suggest getting that dremel bit....I ate threw 3 bits and called it a day, I used a file from that point on...installed and very happy!
Old 07-02-2008, 06:19 AM
  #107
BriGuyMax
Turbo Whore
BriGuyMax's Avatar
Tungsten Carbide bits FTMFW
Old 07-04-2008, 07:18 AM
  #108
3m wol8
3m wol8's Avatar
how's everything working out Mr. Toe?
Old 10-12-2008, 08:39 AM
  #109
MATTY_T
MATTY_T's Avatar
very nice! thanks a bunch!
Old 10-16-2008, 09:04 AM
  #110
sry110
sry110's Avatar
I am considering doing this install myself within the coming weeks. Here are a few questions that the tuturial didn't address:
1) I am guessing you need to support the bottom of the rear spring cup / mount with a hydraulic jack, remove the toe bolt, then let the spring cup down slowly?
2) Is it safe to say that having an air impact wrench at my disposal will make this job much, much, much easier?
3) In the last picture of the tutorial the bolt head is nowhere need concentric with the round flatwasher. Is this the desired end result?
4) If I don't smear dirt and grease on my hands and arms will my girlfriend still love me and cook me dinner?
Old 10-16-2008, 04:37 PM
  #111
Dave 90TT
350Z 2+2
Dave 90TT's Avatar
1. Yes
2. Air impact wrenches make everything better.
3. Not sure exactly what you are saying here.
4. If she doesn't make you a sammich while you are working, ditch her and get another one.
Old 10-27-2008, 10:58 AM
  #112
MIAPLAYA
MIAPLAYA's Avatar
Glad to see the write up is still of good use.
Old 10-28-2008, 11:11 PM
  #113
ByThaBay
ByThaBay's Avatar
I made a video for this:
http://x.infinitihelp.com/forum/show...-kit-4597.html
Old 11-16-2008, 11:09 AM
  #114
MIAPLAYA
MIAPLAYA's Avatar
Originally Posted by ByThaBay
I got your PM but I can't edit the main thread anymore. Thanks for posting the video.
Old 12-13-2008, 12:07 AM
  #115
Fuegostyle
Fuegostyle's Avatar
Has anyone watched the video posted above? They dremeled out equal sections to the left and right of the hole. I thought you were supposed to make the template flush with the outer edge of the hole and carve so that the hole is elongated toward the center of the car. Anyone else carve out equally on both sides of the hole? Did they do it differently because it was a G35? Overall, the video is very helpful.
Old 01-16-2009, 12:24 PM
  #116
ShanesG
ShanesG's Avatar
nvm stupid question!
Old 01-17-2009, 11:52 PM
  #117
JL350ZSD
JL350ZSD's Avatar
Just installed mine tonight. This write up helped a ton. That dremel 115 bit is key. Took me maybe 2-3 mins to cut per side. I picked one up at lowes for $6. Never would have known about that is it wasn't for the write up.
Old 01-31-2009, 09:06 PM
  #118
zhuangzi
zhuangzi's Avatar
stupid question, but... the dremel bit is this one right?
http://www.lowes.com/lowes/lkn?actio...115&lpage=none
Old 02-01-2009, 07:14 AM
  #119
black04ninjaZ
black04ninjaZ's Avatar
I used that bit when I did mine a couple weeks ago, and must've done something stupid, like I normally do. I bent the freakin shaft of the bit about 95% through the project. Filed the rest. I would suggest getting the tungsten carbide like BriGuyMax said. That should work even better than the bit me and you found. Hope that helps
Old 02-01-2009, 11:30 AM
  #120
JL350ZSD
JL350ZSD's Avatar
Yep, thats it
Quick Reply: SPC Toe Bolt install write up with pics courtesy of Protocav.
