How to make your own APS tire bands...
Sweet, thanks for the input. I am going to try and make some of these bands using techniques I have read about previously as well as incorporate some of my own ideas. I plan to test the final product and maybe offer it to the Z community as an alternative option to keep TPS on aftermarket wheels. Wondering how much interest there would be?
Check here for the method that has held up for 3 years:
https://my350z.com/forum/showthread....&highlight=jak
Make sure you read the whole thread, as Jak's modification really works!
Mike (had sensors bouncing around until using this method)
you guys know what , im just gonna take my insturment panel apart n remove the bulb for the low pressure lite . ive been checkin air pressure in my tires manually for the last 20 yrs and it hasnt hurt me yet . screw all the hassles.
Do you check them daily? I drove off to work one morning and had the low pressure alarm go off. Sure enough, the pressure was below 28 psi. I was lucky that I wasn't getting a flat tire but it could have easily been that. That alone makes the TPS worth it IMO.
is there a way to remove the tpms??? oh my god i would be soo flippin happy i haven't had a working tmps since the first week i had the car (cause i changed wheels due to a track accident)
Please ADVISE can it be done
Administrator
Originally Posted by TIMROD1011
Why not just glue the TPS to the inside of the wheel with a good epoxy? Most wheel weights are glued on or just sticky foam tape.
Ideas...........??????
there are many other forces at work here. when turning, hitting a bump, braking, accelleration. the forces on the weights are not just outward, the forces are in all directions. there are epoxies available that can hold 1000's of lbs per sq. in.
I wouldn't feel comfortable with a permanent mount, so I used bands. But you could try the epoxy and let us know how it works for you. It may be a much better way for some people.
I'm not trying to be an ***, but wouldn't it be easier to just buy a counterbore with a pilot and machine the valve stem hole on the new rim to accept the factory sensor? Are the stock rims threaded to accept the sensor/valve stem?
You can buy the correct cutting tools for alot less and after you're done with them you could pass them on.
I'm a machinist and the whole clamp thing looks like a pain.
I've got an 05 Coupe and I was fishing for info and ran accros this thread.
