How to make your own APS tire bands...
Old Mar 2, 2007 | 01:08 PM
  #61
VO...'s Avatar
VO...
Administrator
Originally Posted by jmjftw
I'm not trying to be an ***, but wouldn't it be easier to just buy a counterbore with a pilot and machine the valve stem hole on the new rim to accept the factory sensor? Are the stock rims threaded to accept the sensor/valve stem?
The stock rims are not threaded to accept the stock valve. They mount through a hole in the rim and have rubber grommets on either end. The valve stem itself is thread and a nut is used to fasten it to the rim. The sensor it attached to the back of the valve stem.
I hear what you saying, with regards to machining out a new hole in the aftermarket rim. The only problem this would pose is that many people have details rims with complicated rivets and what not. For instance, I have 3 piece HRE's. The valve stem outlet is designed to look like one of the removable rivets. Drilling this out would compromise the seal between the face and barrel of the rim plus it would deform the face of the rim, making it unattractive.
Old Mar 3, 2007 | 06:40 PM
  #62
98sr20ve's Avatar
98sr20ve
Originally Posted by vo7848
To connect the bands to each other, you'll have to cut the appopriate notch at one end of the band, then cut an "arrow" type end at the end of another band.
Do you realize you can just screw all the units into one long band using the existing screws. No need to hack apart the band and make those arrows to insert into the cut portion.
Old Mar 3, 2007 | 06:46 PM
  #63
accordfreak's Avatar
accordfreak
if anybody needs a set, I have an extra set of bands I made, Can accomodate 19" and 20"
http://www.g35driver.com/forums/showthread.php?t=140720
Old Mar 5, 2007 | 11:22 AM
  #64
VO...'s Avatar
VO...
Administrator
This is true. What I was considering was the amount of balance, the added weight of the fastener portion of the band would throw the wheel's balance off, making it necessary to add more wheel weights to the barrel of the rim.
Old Apr 13, 2007 | 06:22 PM
  #65
theaxe1149's Avatar
theaxe1149
Default just a thought
Most air conditioning duct band go up to 24" dia.
no mods required
Old Jul 26, 2009 | 12:22 PM
  #66
deobiet's Avatar
deobiet
what section in the home depot would these plywood spacers be under?
Old Jul 28, 2009 | 07:32 PM
  #67
Thermal1's Avatar
Thermal1
They are near the plywood. I found them at the endcap of an aisle.
Old Aug 14, 2009 | 09:28 PM
  #68
LegionnaireZ's Avatar
LegionnaireZ
I guess i was luck to have my sensors mount up to the wheels as if they were factory... sweet deal!
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
