|| red brembo ||
Old Feb 2, 2009 | 11:39 PM
350Z_NOW's Avatar
350Z_NOW
Default || red brembo ||
i know it's been done with the brush + paint.... so I used spray paint...
stripped it, had to do multiple coats,wash and spray the paint remover every 30 mins (3-4 times) steel brush helps for corners. doesn't have to be bare metal. you can see the yellow + black primary coat then gold finish
primered + filler for deep scratches and such, tape your bleeder nipple and tighten it, also behind the caliper where the hardlines connect. so no break fluid leak that can mess up your project. took the bleed nipple for taping
after primer/filler is dry, scuff it with 3M scuff pad (red) or 360-400 grid sand paper, then apply alchohol on the microfiber cloth then wipe it down for dust or oily areas, spray the red caliper paint. light coats then mild...this red caliper paint isn't quite the brembo red. so i sprayed over it with dupli color cardinal red cc it matches my friends brembo GT red paint.
spray the clear coat when the paint is dry. i spray about 4-5 coats. as you can see there are still orange peel... so tomorrow i'll wet sand it with 1000-1200 grid
I will post pictures of wet sanded + buffed + polished tomorrow....finish touch, my brembo decal just arrive today in white gloss, exact size
more orange peel....BAD!
here's a sample of wet sanded, buffed, polished, waxed, finished
now the finish project + brembo decals
THANKS FOR VIEWING !!!
Old Feb 3, 2009 | 02:54 AM
kihun's Avatar
kihun
why......why...... i love gold brembo.. too many civics have painted red calipers.
Old Feb 3, 2009 | 03:03 AM
DelayedZ's Avatar
DelayedZ
Cause if you're going with a design for your car, gold isn't exactly the best color, lol.
Old Feb 3, 2009 | 04:34 AM
Z04's Avatar
Z04
hate to say, but i really do not want to see what the effects of that aircraft paint stripper did to the rubber seals of the brake pistons. i am sure if it was strong enough to strip paint it damaged those pretty good. good luck
Old Feb 3, 2009 | 04:53 AM
06blueZ's Avatar
06blueZ
+1 i was going to comment on the same thing.. cant be good for the rubber.
Old Feb 3, 2009 | 04:57 AM
SuperBlack350z's Avatar
SuperBlack350z
plus, i hope you scuffed up the gold part after some brake cleaner so the red paint will stick well and not flake off where the gold was left on there. I think you could of done a better tape job around the pistons like Z04 said.
Old Feb 3, 2009 | 05:37 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
pistons seals will not be happy with this
Old Feb 3, 2009 | 07:47 AM
ecorona6's Avatar
ecorona6
We were all thinking the same thing after the first pic, "the seals".
Old Feb 3, 2009 | 10:16 AM
350Z_NOW's Avatar
350Z_NOW
the seals are actually tape "clear" and nothing went through... I check. I got it guys c relax.......and DELAYEDZ I agree with you, when I think of brembo i see red.... keep in mind im not painting a normal caliper....like civics. dont get me wrong i like civics, had a couple in the past but never painted my caliper haha because i have spoon calipers
Old Feb 3, 2009 | 10:24 AM
06blueZ's Avatar
06blueZ
oooookk, there's no clear tape in the first pic, whatev!
Old Feb 3, 2009 | 11:03 AM
ReV74's Avatar
ReV74
Great Job 350Z Now!
Looks good spray painted. I like the close up pics.
Old Feb 3, 2009 | 02:54 PM
350Z_NOW's Avatar
350Z_NOW
thanks reV74...... more finished pics updated!
Old Feb 3, 2009 | 07:23 PM
blackz123's Avatar
blackz123
pics on car or fail
Old Feb 3, 2009 | 07:29 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
they look good!
my other concern is will the paint last through the heat?
Old Feb 3, 2009 | 07:38 PM
lgear080's Avatar
lgear080
agreed... cutting corners on this seems... well, you know
Old Feb 3, 2009 | 08:01 PM
350Z_NOW's Avatar
350Z_NOW
i did this to my evo 9 (mr) last year, same red, still looks sharp,shiny,no flakes, no cracks, i'm actually looking at it right now. i didnt post this to get critics, i posted this to share it to the ones that might be interested in doing the same thing....
Old Feb 4, 2009 | 03:10 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
its looks good. If youre comfortable with what you then thats fine.
Im just under the impression that the non-high temp paint will eventually peel off. If not then great. It looks superb and I would love to custom paint my stoptechs.
Old Feb 4, 2009 | 08:34 AM
350Z_NOW's Avatar
350Z_NOW
i used high temp, superb? yes....! stop-tech? go paint it....
Old Feb 4, 2009 | 07:04 PM
SA Z-boi's Avatar
SA Z-boi
Looks good man, get some pictures up of them installed.
Old Feb 4, 2009 | 07:50 PM
Spork's Avatar
Spork
You mixed high temp spray paint with normal clear coat?
I see no clear tape in the first picture as well.
I fear your seals will be done for.
Looks decent though, just don't do constant heavy braking, otherwise the clear may start to burn off.
