Cooling the rotor brakes
Old Nov 17, 2010 | 04:13 AM
E tempo !'s Avatar
E tempo !
Default Cooling the rotor brakes
hi,
For my next trainings track i imagine how to cooling my rotor brakes. It's just one solution but i think it's better than nothing...
Old Nov 17, 2010 | 04:17 AM
idrive_MD's Avatar
idrive_MD
Simple and effective (I hope). Keep us posted if you notice the difference.
Old Nov 17, 2010 | 04:25 AM
E tempo !'s Avatar
E tempo !
Yes , i hope too , but i will drive on the tracks just for my pleasure , not races, so i think it's will be better, when i will go on the track i posted for you tell what i mean
In our "notre350Z.com", we have "Taurim", my cooling system was inspired by him. He cuts has 350 Z all shares are totally modified (frame, brakes, suspensions, engine etc…) only for the Nurburgring Track.
http://www.youtube.com/profile?user=...10/3nshOCahRsc
he's a good pilote , not me ( smile)
Old Nov 17, 2010 | 04:57 AM
Kwame's Avatar
Kwame
If you were going to cut a hole through the lower splash shield you might as well have put NACA ducts in it (ala the NISMO Motorsports kit) instead of just having the hose hanging down there like that. I commend your effort nonetheless.
Old Nov 17, 2010 | 05:02 AM
herrschaft's Avatar
herrschaft
https://my350z.com/forum/autocross-r...rake-duct.html
Old Nov 17, 2010 | 05:28 AM
E tempo !'s Avatar
E tempo !
yes thank you, but i think NACA ducts are ok in the front bumper but if my duct exceeds there more air which returns under the car & also i don't want to see thems, i would like to save the front bumper look.
Old Nov 17, 2010 | 06:55 AM
Kwame's Avatar
Kwame
NACA ducts in the splash shield...
Much cleaner IMO
Old Nov 17, 2010 | 07:07 AM
E tempo !'s Avatar
E tempo !
Much cleaner IMO
wow, it's a very good idee and i really like it, it's very clean ! with my lip in front the bumper do you think enough air can enter if doesn't air duct exceed ?
Old Nov 17, 2010 | 07:09 AM
RandomHer0's Avatar
RandomHer0
Thats exactly what I've decided to do, NACA in the shield.
Have you compared temps kwame?
Old Nov 17, 2010 | 07:13 AM
E tempo !'s Avatar
E tempo !
not yet ...
where is your Naca duct , under your splash shield or in your front bumper ?
Old Nov 17, 2010 | 07:19 AM
RandomHer0's Avatar
RandomHer0
havent done it, I will do what Kwame proposed, put the NACA on the splash shield, you wouldnt doit on the front bumper.
If you want bumper you wouldnt use a NACA duct.
Use one made for the bumper.
http://www.pegasusautoracing.com/gro...oupID=DUCTBUMP
Old Nov 17, 2010 | 07:20 AM
Kwame's Avatar
Kwame
If you have a front lip I really don't think you will get all that much airflow to your hoses with either the setup you have now or with the setup I have suggested. The whole point of any functional front lip is to prevent air from going underneath your vehicle in an effort to decrease or prevent lift. A much better location to feed cool air to the rotors would be from your front bumper in your situation.
It's not my car, so I cannot say. It's from this thread...
https://my350z.com/forum/autocross-r...ake-ducts.html
Old Nov 17, 2010 | 07:26 AM
E tempo !'s Avatar
E tempo !
yes, you're right ...if one day the lip will be broken , no problem i use your solution thank you for your help
Old Nov 17, 2010 | 07:27 AM
Kwame's Avatar
Kwame
No Problem, good luck.
Old Nov 17, 2010 | 07:29 AM
E tempo !'s Avatar
E tempo !
RandomHer0 , thank you too for yourd links
Old Nov 18, 2010 | 02:35 PM
kwadell's Avatar
kwadell
Nice simple set up. I was thinking of doing a set up something like this since it seems like there is a good pocket right there where a low profile inlet like this would fit nice. I did my inlets in front of the radiator and the routing is a lot harder and adds more pressure drop than a system like this. What is the inlet grate material?
Old Nov 18, 2010 | 03:04 PM
E tempo !'s Avatar
E tempo !
yes, you have more pressure with your system. My flexible have a big diameter--->not easy for the routing in front the radiator....
steel grids (recovery)
aluminium..
Old Nov 18, 2010 | 08:06 PM
Shawz1102's Avatar
Shawz1102
i love his videos, seen them a long time ago
Old Aug 10, 2011 | 04:12 AM
E tempo !'s Avatar
E tempo !
My new system for the hot brakes temp on track :
Old Sep 1, 2011 | 05:08 PM
kno's Avatar
kno
hey tempo i was wondering how did your setup perform?
