How-to: Change Brake Pads
Old Mar 31, 2019 | 08:12 PM
  #301
noobie_1337's Avatar
noobie_1337
Hello. About to replace my brake pads and reapply grease to my caliper pins. Just want to make sure if these caliper grease will work fine for the caliper pins and not damage the rubber housing.
Permatex 85188 Ultra Disc Brake Caliper Permatex 85188 Ultra Disc Brake Caliper
CRC 05359 Brake Caliper Synthetic Grease CRC 05359 Brake Caliper Synthetic Grease
Sil-Glyde AGS BK4 Brake Lubricant Sil-Glyde AGS BK4 Brake Lubricant
and which one would you recommend..??
Thanks
Old Jun 10, 2021 | 08:22 AM
  #302
superfishyall's Avatar
superfishyall
5 Year Member
I know this is a super old thread and this question has probably been answered somewhere before but I can't find it. One of the rear brakes is squealing badly. Pads and rotors were replaced about 3 months ago. We pulled the top pin in the caliper and tried to rotate it down on the lower pin (as directed in many places) and it only rotates part way and then hangs up on something. In videos on Youtube, it swings down with no resistance. We also loosened the lower pin - same result. We didn't try to force it. Should we? I couldn't get the lower pin all the way out because part of the suspension is in the way. I could take the entire caliper off by removing the two larger bolts but am hoping to avoid that. Thanks.
Old Jun 10, 2021 | 09:49 AM
  #303
travlee's Avatar
travlee
Master
just take the caliper off
Old Nov 28, 2022 | 05:16 AM
  #304
kshaw's Avatar
kshaw
Yes. It may require some force. I have used a huge screwdriver, a breaker bar, and even gently tapped with a small sledge hammer to get them down.
