Infiniti G35 Sedan Suspension replacement
Hey,
I've been searching online for replacement parts until i reached the forum, i found that an alternative exists for most parts.
Parts i'll need to service include:
Front arms Or bushings (the ball joint had me lost)
Rear arms Or Bushings
Front & Rear Shocks and mounts
I'm honestly in doubt to whether i should change the bushings instead of the whole arms and if the 350z/ G35 Coupe aftermarket Poly bushings fit.
Your Input is much Appreciated
It's an 05 Sedan G35 RWD
Welcome and unless the suspension arms are damaged (bent or broken), it's fine just to use a shop with a press and replace the bushings with NISMO or Whiteline bushings. As for the dampers, most folks around here like Bilstein B9s, although I'm partial to the Koni Sport shocks.
ZSpeedPerformance
Drivetrain
15
Oct 16, 2019 07:39 AM
- bigc -
Feb 7, 2017 01:28 PM
