Tein CS Problems
Old Nov 29, 2004 | 05:55 AM
NismoGCoupe's Avatar
NismoGCoupe
Default Tein CS Problems
Ok heres the problem I've had my Tein CS coilovers installed since May of this year I wasn't having any problems with them at all untill about last month and what seems to be happening is when driving down bumpy roads it sound like the rear passenger spring/purch is loose and making knocking sounds, so I had it checked out to see if they where installed incorrectly but the mechanic I brought it to said they were installed correctly and they couldnt figure out why it was making noises, we checked the shocks to see if the we making the noises(if they were blown) but they were fine. This may sound stupid but it seems in the morning when its colder out it knocks alot more then in the afternoon when it warmer out, did anyone have this problem with these coilovers making knocking noises or know what this sound can be coming from?
Old Nov 29, 2004 | 12:19 PM
NismoGCoupe
bump for some help if I cant get this figured out I think I may just get rid of these coilovers, I cant take the noises any more
Old Nov 29, 2004 | 12:54 PM
GoSooners's Avatar
GoSooners
Did you check the upper shock mount? There may be something loose up there? Maybe a bolt broke? Make sure those 2 bolts that hold the upper shock mount to the chassis of the car is torqued to 21 ft-lbs. Those are factory torque specs. You'll probably have to take off your rear wheel to check if your car is lowered quite a bit.
Old Nov 29, 2004 | 04:46 PM
chimchim's Avatar
chimchim
I had the same problem with my CS's. But I also replaced the upper A arm with an adjustable one. It turned out to be a loose ball joint in the upper A arm. There was no visible play in it but you could hear it rattle when it was pulled on. I had it replaced and all is fine.
I remember seeing a TSB for the 350z regarding noise coming from the front suspension. The solution was to re-torque the bolts holding the upper A arm. If the shocks are fine, I would check the upper and lower joints for any play.
Old Nov 29, 2004 | 06:02 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
sounds like the upper nut for the strut mount
Old Nov 29, 2004 | 08:05 PM
NismoGCoupe
the sound is coming from the rear passenger side so It cant be coming from the a-arms
Old Nov 29, 2004 | 08:06 PM
NismoGCoupe
that was checked and it was fine
Old Nov 30, 2004 | 07:03 PM
Z1 Performance
Former Sponsor
how was it checked? What is it tightened to?
Old Dec 6, 2004 | 11:43 AM
NismoGCoupe
anyone have any other suggestion, this problem sounds like its getting worse, its making noises on any type of bump now. Its really pissing me off
Old Dec 6, 2004 | 11:45 AM
NismoGCoupe
they tighted it to make sure it was tight but that wasnt the problem cause its still making the noises.
Z1 you think you can take a look at this week and install front and rear camber kit while your at it?
Old Dec 7, 2004 | 07:14 AM
350Zteve's Avatar
350Zteve
Perhaps its the spring perch and not the shock at all. I would remove both and check everything out.
Old Dec 7, 2004 | 09:25 AM
Neadmiken's Avatar
Neadmiken
did they check the sway bar links
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
