WANTED: Pics of 350z with Hotchkis springs
Old Dec 8, 2004 | 04:25 PM
nureulsaranghae's Avatar
nureulsaranghae
Default WANTED: Pics of 350z with Hotchkis springs
Yes, I did search, but all I can come up with is the grey g35.
I want to see them on 350z. either stock wheels or 19's.
thanks guys.
John.
Old Dec 8, 2004 | 04:30 PM
nureulsaranghae
oh, preferrably with stock shocks
Old Dec 8, 2004 | 05:23 PM
vics350's Avatar
vics350
I hope this helps. This is my car before the Hotchkis springs:
Attached Thumbnails WANTED: Pics of 350z with Hotchkis springs-mycarnodrop.jpg
Old Dec 8, 2004 | 05:25 PM
vics350's Avatar
vics350
Here's after the springs. This picture is a bit darker but hopefully you can see the difference. Oh, and I had added the Veilside V1 lip as well.
Attached Thumbnails WANTED: Pics of 350z with Hotchkis springs-mycar3a.jpg
Old Dec 8, 2004 | 05:27 PM
vics350's Avatar
vics350
Here's another picture with the Hotchkis springs:
Attached Thumbnails WANTED: Pics of 350z with Hotchkis springs-mycar3b.jpg
Old Dec 8, 2004 | 05:28 PM
nureulsaranghae
that is exactly what I am looking for, however Only info I can't find is that, just like almost any springs, do Hotchkis springs cause camber wear? if aligned right after install, would I have any camber problems with this?
thanks guys, More pics will be appreciated also
thanks
John.
Old Dec 8, 2004 | 05:31 PM
vics350's Avatar
vics350
BTW, I had them installed in June and a few weeks after they were installed I measured about a 3/4" drop in the rear and 3/8" drop in the front. I haven't measured it since then.
Old Dec 8, 2004 | 05:32 PM
vics350's Avatar
vics350
I had the car aligned after the springs were installed and I was told that my camber only needed a minor adjustment to fall within specs. and they were able to dial it in.
Old Dec 8, 2004 | 05:34 PM
nureulsaranghae
so no need to worry about camber wear with these springs as long as I get it aligned after install? Because I just got new tires on my 19's hehe.
thanks
John
Old Dec 8, 2004 | 05:35 PM
vics350's Avatar
vics350
Here's a picture next to my friend's car who has the Tein EDFC setup. His car is dropped approx. 3/4" in both the front and rear. You can see in this picture that the rears of both cars look the same but his front is lower than mine.
Attached Thumbnails WANTED: Pics of 350z with Hotchkis springs-me-and-jeff1a.jpg
Old Dec 8, 2004 | 05:36 PM
vics350's Avatar
vics350
thanks
John
You should have no problem as I have 19's as well.
Old Dec 8, 2004 | 05:40 PM
vics350's Avatar
vics350
Here's one more of the two cars back-to-back. If his car were to have the V1 lip it would be really low. You can see by the picture that my car with the lip is actually still a little higher than his car.
Attached Thumbnails WANTED: Pics of 350z with Hotchkis springs-backtoback.jpg
Old Dec 8, 2004 | 05:47 PM
nureulsaranghae
wow, thanks for posting many good pics, What is he lowered with?
Old Dec 8, 2004 | 06:01 PM
vics350's Avatar
vics350
He's got the Tein EDFC system (costs around 2 grand) which allows him to adjust the stiffness/softness of the suspension at the touch of a button. Also, he can change the drop whenever he wants to by turning a dial on the strut itself. He chose to go with 3/4" drop front and rear for now.
Old Dec 9, 2004 | 05:17 AM
TheBigShow's Avatar
TheBigShow
r u still in spec after settling?
Old Dec 9, 2004 | 01:34 PM
vics350's Avatar
vics350
Haven't checked since the alignment but I haven't noticed any unusual tire wear and the drop still appears to be the same. I've probably only put a couple of thousand miles since June so it may be too soon to tell.
davidm350
Oct 31, 2015 02:28 PM
A_MEISTER
Suspension
Oct 25, 2015 04:50 PM
Paul.
Oct 16, 2015 07:34 PM
CJs_Z33
Sep 18, 2015 12:06 PM
