need to adjust toe and camber front and back, what will do it?
is there a kit of some sort that can do all of this? or what combinations of stuff do I need?
also, Im doing this to fix tire wear issues, but even though Im taking camber out, any chance this will improve the ride/handling?
I have about 8degrees of negative camber, and I dont autocross. tried to get it aligned and they said the stock suspension didnt have enough range to even get it near spec. 5000miles to a tire killing me.
so the A-arms control both camber and toe? do they come front and back or together. Ill go look at them.
FRONT:
A-arms only control camber adjustment and if so designed also caster (isn't one that can do this yet).
Toe is adjusted by the tie rod arms so no additional parts needed for toe.
REAR:
Camber will require adjustable camber rods (several makes available).
Toe, use either the SPC bolts of K-Mac's eccentric bushings. These are the only items that will increase adjustment at the proper angle so it won't affect rear caster.
REAR:
What are the stock specs we should be aiming for? I just had a new set of tires but on and just by eyeballing it the rear wheels seem to have far too much toe out. So I would need rear adjustable toe control rods or rear lateral links? Looking at this page:
http://www.cusco.co.jp/english/e_cont.html
I'm going with the SPC camber arms and toe bolts total cost was about 220 shipped and once I find out if the Cusco arms will add positive camber as well as negative I will be picking those up as well.
seagrasser
Oct 11, 2015 03:27 PM
