Brake pads and slotted rotors installed *pics
Old Jan 18, 2005 | 11:55 AM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
Default Brake pads and slotted rotors installed *pics
I just finished installing my Hawks HPS brake pads and a set of drilled and slotted rotors and I painted my calipers red with the help of my AAA mechanic friend. Once I finished and gave it a test drive, it made so much noise like a whirling noise like the rotors are touching something when it is spinning. And you can hear clunking noises in the rear. I dont hear anything in the front. Did we do something wrong? My friend wasnt here on the test drive and I have yet to ask him why. Here are some pictures of the completion and what happened after the test drive:
Old Jan 18, 2005 | 12:52 PM
baptist's Avatar
baptist
Looks nice mate!
Old Jan 18, 2005 | 12:56 PM
dumbmotor's Avatar
dumbmotor
Your rims are so special. They look fabulous!!!
Old Jan 18, 2005 | 01:01 PM
dumbmotor's Avatar
dumbmotor
It seems to me that the pad and the disc havent match yet.
Old Jan 18, 2005 | 01:20 PM
omarv6's Avatar
omarv6
looks cool
do thy make those for cars with brembos ?
Old Jan 18, 2005 | 01:28 PM
teh215's Avatar
teh215
Did you bed them in?
Old Jan 18, 2005 | 01:30 PM
neur0sis's Avatar
neur0sis
Did you make sure and follow the break-in / bedding instructions for the rotors and pads?
You're supposed to go out and do several hard stops from 30mph to 5mph (don't let ABS kick in) and then, several hard stops from 50mph to 5mph (again, hard enough but not letting ABS take over)
Some pads/rotors have different bedding instructions, so check with the manufacturer, or other posts on this board... but its generally a good idea to break them in, and help mate the pads to the rotors.
Old Jan 18, 2005 | 02:57 PM
cquence 350 [Z]
So you guys are saying they are not broken in yet? should I get a couple of runs going at a higher speed? I got so scared when I heard all the noises coming from the rear. the front was okay, I couldnt hear anything.
Old Jan 18, 2005 | 03:05 PM
zand02max's Avatar
zand02max
I would not bed them in until you get that noise checked out. DO NOT drive until you get the clunk checked out. Call your AAA friend.
Old Jan 18, 2005 | 05:05 PM
Morris's Avatar
Morris
Not sure what your problem is, but they look nice! Which rotors did you get?
Old Jan 18, 2005 | 07:28 PM
cquence 350 [Z]
Thanks, they do look great and I bought the rotors on ebay from rotorpros. I just bought some VHT caliper paint. The outcome looks awesome but still figuring out the problem. I will find out on Friday. My friend told me not to drive it yet until its fixed. I think the shims on the pads are rubbing the rotors which makes the rubbing sound coming from the back. My fronts are okay but the rears are having a problem.
Old Jan 18, 2005 | 07:39 PM
GaryM05's Avatar
GaryM05
Please don't take this the wrong way, but have you checked to make sure that all of the pads were inserted into the calipers in the right direction, with the compound on the rotor-facing side?
Good luck!
Old Jan 20, 2005 | 02:31 PM
cquence 350 [Z]
My friend and I checked the rotors and the gap between the rotors and the calipers were soooo close compared to the stock rotors. And it is still making the metal to metal noise.can anyone can help?
Old Jan 21, 2005 | 02:06 AM
XBS's Avatar
XBS
Veteran
if the rotors are too big take the to get resurfaced then you sould be ok
Old Jan 21, 2005 | 10:05 AM
cquence 350 [Z]
I think its the inner ring. Its not flushed with the rotors. It sticks out and thats what is causing the rotors to be soooo close to the calipers. And I am assuming the rotors are rubbing the calipers.
Old Jan 21, 2005 | 06:27 PM
spdu4ia's Avatar
spdu4ia
is this a flaw of the rotors because i am thinking of getting the same ones?
Old Jan 21, 2005 | 06:49 PM
Cyp's Avatar
Cyp
have you tried putting the rear stock rotors and pads back on again? That way you can check to see if it is your new setup.
Old Jan 22, 2005 | 02:07 AM
cquence 350 [Z]
It is the rotors. Appearantly, the got the wrong batch of rotors, the inner ring is not sitting flushed which causes the outside portion of the rotors to stick out more than usual. The seller that I dealt with is very good about customer service. He sent me a replacement set of rears knowing that it was a defective product. I bought it on ebay from rotorpros.
Old Jan 22, 2005 | 03:30 AM
Da Gimp's Avatar
Da Gimp
Default I hope they get it worked out
I got the same ones:
I got these on ebay
So I hope he sends me the right ones. I also got steel brake lines and redstuff pads to go with them.
Old Jan 22, 2005 | 01:10 PM
cquence 350 [Z]
Default Re: I hope they get it worked out
I got these on ebay
Make sure you send him an email about the inner ring on the rear rotors. So the problem could be solve first hand!
