Having only Front Brembos or Stoptech worth it?
Old Feb 6, 2005 | 10:18 AM
bombrush's Avatar
bombrush
Default Having only Front Brembos or Stoptech worth it?
Was wondering if only getting front Stoptech or brembo brake system worth it?
Is tehre any downside to this?
how much would dealer sell their brembo system OEm brake for?
Old Feb 6, 2005 | 11:03 AM
ZPirate's Avatar
ZPirate
Default Re: Having only Front Brembos or Stoptech worth it?
Yes the front StopTech kit by itself is worth it. See www.mynismo.com (Performance Nissan is one of the vendors that supports this site and where I got my StopTechs) for StopTech kits or the OEM Brembo kit. They sell both.
Old Feb 6, 2005 | 02:22 PM
westpak's Avatar
westpak
SFZCC
I have the Track model Brembo fronts only and it is a tad too front biased on hard braking, I need to get the rears somehow.
If only going for front kit probably better to get Stoptech or similar that are designed as front kits only and probably better balanced with the stock rears.
Old Feb 6, 2005 | 05:11 PM
350ed's Avatar
350ed
Professional
Depends on your usage model. If you plan to track your car, very much so. The Stoptech 13's actually reduce the rear brake temps on hard braking. The 14's increase the rear temps so don't get them. I haven't needed to upgrade the rears. If you plan to track it a lot and are a good driver, you may want the rears too. If you will never track your car (I don't mean autocross), then don't bother.
Old Feb 8, 2005 | 06:39 PM
spf4000's Avatar
spf4000
Being front biased is way better than being rear biased (which is very dangerous). If you want to increase the rear bias, you could try a different combination of pads front/rear, or you could increase the tire width in the front to increase front grip.
Old Feb 14, 2005 | 07:13 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Moved.
Obadabot
Jun 18, 2023 11:31 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
