cost of alignment with camber kit
Old Feb 18, 2005 | 11:50 PM
tractng's Avatar
tractng
Default cost of alignment with camber kit
Guys,
I am still deciding if i want to lower my ride. I have 19" volks gt7 with 30 series in the rear.
I am looking to lower with spring. Just trying to get an idea what the total cost could be.
Is the cost of the alignment tht same with a camber kit? I called Darin of West End Alignment and he told me that it costs $300
I know some people with Tein S and Hotchkiss don't need camber kit, but i am just looking at the possible cost.
Tony
Old Feb 19, 2005 | 05:44 AM
mrbader's Avatar
mrbader
I have 20's and I've lowered my car with Eibach springs. It's only lowered an inch. It looks great. Rides nice. Performs better. I did not even align my car after the wheel change and lowering as with the Eibach springs pro kit doesn't change the factory specs in the wheels. So you keep the negative camber it came with and it doesn't get any greater. The only bad part is that I burn thru tires in 10K miles in the rear.
That's just my experience... also, I own a Motorsports shop... and $300 to install springs & sways is a good price.
Old Feb 19, 2005 | 08:00 AM
tractng's Avatar
tractng
mrbader,
I mean $300 bucks just for an alignment that has a camber kit on. If not, then its $80.
Tony
Old Feb 19, 2005 | 08:26 AM
mrbader's Avatar
mrbader
they're installing springs and sways for $80? if so, that's amazing but I guess out in LA there's a shop on every corner that can do the install. I wouldn't touch it the install under $200... 4 wheel alignment $80... camber kit I would have to find a price.
I didn't use a Camber kit on my car... however I used the Eibach springs... 1" lower spring... no camber change and keeps factory specs.
Old Feb 19, 2005 | 09:07 AM
Darth Bobo's Avatar
Darth Bobo
Originally posted by mrbader
...So you keep the negative camber it came with and it doesn't get any greater. The only bad part is that I burn thru tires in 10K miles in the rear.
How can you keep the same specs yet burn through tires so fast?
Old Feb 19, 2005 | 09:16 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
led foot of death?
Old Feb 19, 2005 | 09:30 AM
mrbader's Avatar
mrbader
I actually got about 13K out of the back tires. The front are still in great shape and I have about 16K on those right now with much more to go. The treadwear rating on these tires is real low. But they ride real nice.
GR Beta FK-451
Exotic looks, style and performance.
285/30ZR-20 95 B
Specifications:
Treadwear: 280
Traction: A
Temperature: A
Speed Rating: ZR
Old Feb 19, 2005 | 03:35 PM
___DJK___'s Avatar
___DJK___
The original question was never answered.
If it helps you, It cost me about $300 to get my car aligned and camber adjusted (Kinetix camber arms and traction rods). This was done in the LA area. I have over 10k miles on my tires with no signs of unusual tire wear.
Old Feb 19, 2005 | 08:41 PM
tractng's Avatar
tractng
DJK,
Thanks man. Did you have it done at West End Alignment too?
Tony
HoBrahYouStink
Jun 24, 2016 10:58 PM
