Spring Compressor?? and installing springs....
Old Feb 20, 2005 | 04:55 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Cool Spring Compressor?? and installing springs....
How does one aquire a spring compressor? Or does one not, due to the specialized purpose of such an contraption.
I would like to install my springs whilist I install my rims. I do not trust any shop with my volks. Discount tire scratched my 5zigens. They were about the only shop around I simi trust with the Z...
If anyone can advise me, thank you in advance!
Old Feb 20, 2005 | 05:24 PM
protocav's Avatar
protocav
luckily, there isn't much preload on the stock springs, so a spring compressor is not necessary. just stand on the spring when you are loosening the bolt withe an impact gun.
Old Feb 20, 2005 | 05:26 PM
2003z's Avatar
2003z
thats real safe! Autozone rents spring compressors for free. I bought a set from harbor freight tools for $10.
1nate7's Avatar
1nate7
You can "rent" one from Autozone, but its really a fully refundable deposit. Make sure you get the "strut spring tool" and not the "coil spring compressor".
Old Feb 20, 2005 | 05:38 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
thanks for the advice!!
is an impact wrench necessary to break the bolts loose, dumb question but I would rather not have to borrow or find one If I dont need to.
Old Feb 21, 2005 | 03:26 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
I ordered my springs today!
I spoke with Tony@performance(?) maybe, who ever it was thanks for talking with me on the phone!
I didn't want a full 1 inch drop so I went with Tein S-Tech springs.
Old Feb 22, 2005 | 07:53 AM
King Tut's Avatar
King Tut
DO NOT, I REPEAT DO NOT FOLLOW THIS ADVICE. Is it worth losing an eye to save 15 minutes. Always use a spring compressor when removing OEM springs. As mentioned most auto parts stores will let you rent some and if you plan on doing this job in the future I would recommend purchasing a set as I have done.
Old Feb 22, 2005 | 07:54 AM
King Tut's Avatar
King Tut
An impact wrench is definitely not needed, but a good breaker bar would be recommended.
Old Feb 22, 2005 | 11:01 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
thank you
Old Feb 22, 2005 | 12:11 PM
2003z's Avatar
2003z
Compressor isn't needed, but highly recommended. The spring compressor would be a biatch to tighten without one.
tip - You need to compress the spring enough so that it is totally free to ubolt the strut from the strut hat. And an impact wrench really helps for this part too.
Old Feb 22, 2005 | 12:44 PM
protocav's Avatar
protocav
you clowns are getting awfully worked up about this.
i have lowered over 20 G's or Z's, and have never once used a spring compressor EVEN THOUGH I OWN ONE!!
there is very little preload, and i assure you that you will not be losing any eyes over it.
sheesh!! like a group of overprotective moms.
Old Feb 22, 2005 | 01:19 PM
MIAPLAYA's Avatar
MIAPLAYA
Ditto I installed my B&G springs without a spring compressor as well. On the stock springs I used a breaker bar on the top strut nut while still on the car. Re-installing my new B&Gs required a little pushing down on the upper mount but it was nothing that I couldn't do without a spring compressor. On hondas I could see needing a spring compressor but my last two Nissan didn't have much pre-load and I was able to install my springs with no trouble at all. AND NO SPRING COMPRESSOR...
Old Feb 23, 2005 | 05:32 AM
King Tut's Avatar
King Tut
You can take these guys advice, or you can go by the 350Z Factory Service Manual.
Attached Thumbnails Spring Compressor?? and installing springs....-springs.gif
Old Feb 23, 2005 | 08:21 PM
tractng's Avatar
tractng
Guys,
I just ordered springs too (hotchkiss). But I like to know the type of tools needed to install this suckers.
Also, what is the "rubber" like in the picture. I know its some kind of dampening (noise). How does it go in or what will hold it? Please be specific.
Btw, do you take out the whole assembly (strut) off the car. I read the how to on active tuning site.
Thanks in advance.
Tony
Attached Thumbnails Spring Compressor?? and installing springs....-hotchkiss-springs.jpg
Old Feb 24, 2005 | 05:05 AM
King Tut's Avatar
King Tut
That black piece looks like a bump stop. It helps the strut not fully compress when hitting bumps. The 350Z set probably won't come with any. You do have to completely remove the front strut assemblies like in the picture above to remove the OEM spring and replace it. The back is just a couple bolts and the spring comes out and you put in the new one.
Old Feb 24, 2005 | 11:34 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Originally posted by tractng
Guys,
Thanks in advance.
Tony
just got my teins today... they hint about these rubber things. They supply a chart with how much of a rubber thing should be cut but for the Z, there is nothing listed.
Old Feb 24, 2005 | 12:51 PM
tractng's Avatar
tractng
Guys,
So the rubber won't be supplied/needed in the Z?
Thanks,
Tony
Old Feb 24, 2005 | 03:08 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Guys,
Thanks,
Tony
thats what Im thinking tony
Old Sep 16, 2006 | 04:03 PM
JoeyFyed's Avatar
JoeyFyed
Old Sep 16, 2006 | 05:32 PM
Eazzy's Avatar
Eazzy
NNNNOOOOOOOO Impacts, and I have never used a compressor---Just gotta put ur A$$ in it.( Thats on the bolts ) Springs are a snap. DONT GETEM UPSIDE DOWN!!! And position properly in the Rubbers
