New Stoptech rotors = wash them right?
Old Mar 14, 2005 | 01:00 PM
derek173's Avatar
derek173
Question New Stoptech rotors = wash them right?
I just got my new stoptech rotors, I am pretty sure I read here that you are supposed to wash them prior to use. If my memory serves me right it mentioned to use soapy water (dish soap?) and not brake cleaner. Is that right?
Is there any other prep work before I install them?
Old Mar 14, 2005 | 01:08 PM
ZPirate's Avatar
ZPirate
That is what the instructions said when I purchased my brake kits. Wash them with soap and water. Try the Stoptech website for specific instructions.
Old Mar 14, 2005 | 01:17 PM
King Tut's Avatar
King Tut
Yep, soap and water with like a Scotch Guard pad or something with more roughness then just a sponge. You will know you did it right when they dry and start rusting a little.
Old Mar 14, 2005 | 02:56 PM
John's Avatar
John
Or you can do what I did and go out and break in a new set of pads. The oil finish the Stoptechs came with provided for an impressive smoke display when I bedded in the new pads and rotors...
Old Mar 14, 2005 | 03:17 PM
derek173's Avatar
derek173
how long have you had them? any problems? I am asking because I looked the 350z BBK install instruction and several time they mention you have to wash them! I washed mine but was wondering?
Old Mar 14, 2005 | 03:22 PM
John's Avatar
John
I've had the Stoptech BRK Aerorotors for about 6 months now with no problems, only windshield kissing goodness at the track.
Old Mar 14, 2005 | 07:34 PM
derek173's Avatar
derek173
Sounds good I just got them
Old Mar 15, 2005 | 04:54 AM
King Tut's Avatar
King Tut
You are supposed to remove the anti-rust coating from the rotors PRIOR to bedding in the pads. Making the pads remove the coating has a chance that they won't bed properly. Stoptech says clearly to wash the rotors in both install manuals and on a couple special sheets of paper included with the kit. They are serious about removing the coating before bedding in the pads.
Old Mar 15, 2005 | 12:09 PM
J Ritt's Avatar
J Ritt
Yes, ideal is to wash the rotors with soap and water before install. You can use a rag or a scotch brite pad. There's a thin film of protectorant on them to prevent rust when sitting on our shelf. Wash them off, and bed them in according to these guidelines:
http://www.stoptech.com/whitepapers/bedincontents.htm
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
