Sway Bar Database
Old Apr 11, 2007 | 08:38 PM
  #61
labelworkshop75's Avatar
labelworkshop75
hey everybody. I have the HKS True Dual Exhaust and I was trying to get a Nismo sway. Would this clear the exhaust? If not which ones would?... thanks
Old Apr 12, 2007 | 07:53 AM
  #62
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
should be no problem, though there are better sways out there
Cusco fits for sure, as does Hotchkis
Old Apr 12, 2007 | 08:22 PM
  #63
jreiter's Avatar
jreiter
You probably shouldn't get the Nismo sways unless you are matching them up with the Nismo suspension. Their stiffness ratings are a bit weird for most suspensions, including stock. I believe the front is only slightly stiffer than stock, while the rear is actually less stiff than stock (according to what's been posted around here). Plus, they are not adjustable.
Old May 20, 2007 | 07:41 PM
  #64
JAM3Z's Avatar
JAM3Z
Phenom
im thinking about getting either the hotchkis or cusco sways. obviously, the cusco is a good bit more expensive. is there an appreciable difference between the two, or am i just throwing money away with the cusco.
Old May 21, 2007 | 09:18 AM
  #65
Alberto's Avatar
Alberto
Cranky FI Owner
I was gonna do Cusco (cuz I prefer solid) but I want an adjustable rear bar as I dont want to much oversteer. My current JIC set-up handles really well-after some shock fine tuning this weekend at the dragon. Im likely gonna get Hotchkis bars as they are adjustable and inexpensive.
Old May 31, 2007 | 06:31 PM
  #66
goodkd's Avatar
goodkd
My Hotchkis sway bars arrived today. They are the new ones with the four way adjustable front. I was surprised to see thier recommendations were still for the old ones (three way adjustable and different stiffnesses). I have done a number of searches and found two recommendations for the NEW sways:
#1) F: Second stiffest (+82%) R: Softest (+80%)
#2) F: Stiffest (+129%) R: Middle (+125%)
I know the only way to really know is to install and try. Just seeing if there is consensus out there for a good/smart starting point.
Other specs of potential importance: 19s, 245/275 setup, lowered 0.6" with RS*R Ti2000s.
Thanks
Old Jun 12, 2007 | 03:07 AM
  #67
G35cTT's Avatar
G35cTT
curious if any has the 350evo sways w/ a dual exhaust like the GReddy, APS or HKS?
Old Jun 12, 2007 | 07:48 AM
  #68
moxy350z's Avatar
moxy350z
Default Hotchkis TVS Stage I kit.....Just picked it up....
I just picked up my Hotchkis TVS STage I Kit up today.
For a medium setting on the street what setting on the sway bars would be best?..........
Old Jun 16, 2007 | 11:36 PM
  #69
jreiter's Avatar
jreiter
Many people with the Hotchkis bars start with both of them on soft (since they are both still stiffer than stock even on the softest settings), then crank them up from there for fine tuning. I ended up going with both of mine on medium and I like the way they perform on the twisties with the stock springs. Where you end up with your's will depend on other suspension mods you've made. If you've already installed springs which increase the rear stiffness a lot, then you may prefer the swaybars to be medium in the front and soft in the rear.
Old Sep 27, 2007 | 10:14 AM
  #70
Motormouth's Avatar
Motormouth
ok, I know the differences in solid vs hollow swaybars have been discussed, but it's always in relation to max stiffness...
my question is, if it was measured that both bar types had the same exact stiffness, we will say 125% over stock, is there a difference in the action of the swaybar? does one feel better than the other, one have a slight delay where it deforms then stiffens, etc.
I like the idea of hollow for the fact of the weight savings... my friend has the Evo bars and they feel like 40lbs!!
I hope this makes sense, if not I will try again
Old Sep 27, 2007 | 01:39 PM
  #71
stunnashadeson's Avatar
stunnashadeson
Intalled the Tanabe Rear Sway bar and its a night and day difference. The car feels so much more stable and planted. Body roll is pretty much eliminated and all around the car feels alot sportier. I would have to say that the say bar improved handling of the vehicle more than the coilovers that i previously installed. Props to Tanabe for a Great Product!!!
Old Sep 30, 2007 | 10:42 AM
  #72
Sleepy79's Avatar
Sleepy79
I can't seem to find much info on the H&R sways, stiffness and clearance for dual exhaust (HKS hi power more specifically)
Any info on Progress sways as well would be useful.
Old Sep 30, 2007 | 11:22 AM
  #73
mw9's Avatar
mw9
anyone tried cobb tuning combo sways/springs?
Old Sep 30, 2007 | 11:54 AM
  #74
gambino's Avatar
gambino
yep, thats what I have on my car. I absolutely love it! Car looks and handles great. I am thinking of stiffening the sways a little bit more as they are on the softer settings
Old Oct 8, 2007 | 09:02 PM
  #75
terrasmak's Avatar
Anyone actually know the numbers for the Stillen bars???? I cant find them posted anywhere , just the " up to 70% stiffer " I'm trying to set up a friends car , I know the rates my car has with my Hotchkis for a good strarting point.
Old Oct 23, 2007 | 04:56 PM
  #76
webcarconnection's Avatar
webcarconnection
My hotchkis arrive today, I have the Tein Spring (the ones that not drop much) which set up do I put? also my car have around 600 whp and I use it for street racing... any help on which hole to put the sway bars will be very helpful...
Thanks in advance
Old Oct 28, 2007 | 08:36 AM
  #77
Gsedan35's Avatar
Gsedan35
Thanks in advance
2nd hole up from the end of the arms in the front. Given the power you have I would start with full soft in the rear and test, moving up to med in the rear only if you still can get the power down you want to on corner exit.
Old Oct 29, 2007 | 11:36 AM
  #78
webcarconnection
Thanks! I put the front sway bar on the first hole to test it because I feal the Teins a little stiff, back sway is in the first ones... If I change back to the stock springs, which holes do I put both of then?
Old Oct 31, 2007 | 07:05 PM
  #79
silviakoko's Avatar
silviakoko
anyone who have xo2 and stillen sway do you have fitment and clearance issue? please pm me, please
Old Feb 17, 2008 | 10:05 AM
  #80
sbZenth's Avatar
sbZenth
fixed it.
