Brake Master Cylinder
Old Apr 25, 2005 | 03:29 PM
mchapman's Avatar
mchapman
Default Brake Master Cylinder
Does anyone know if the Track model 350z has a different sized brake master cylidner to the Touring model?
I can ask Nissan parts for the two part numbers if I can get a Chassis / VIN number of a Track model 350z.
Thanks
Old Apr 25, 2005 | 07:23 PM
Lawn Dart's Avatar
Lawn Dart
I believe the only difference is the VDC and non-VDC master cylinder. The Track model and Touring model should have the same master cylinder being that they both have VDC.
Old Apr 25, 2005 | 08:33 PM
mchapman's Avatar
mchapman
In Australia the Touring model does not have VDC.
Im trying to find out if the brake master cylinder is the same size in the Brembo and non-Brembo Zeds to determine if the non-Brembo Zed's brake master cylinder can drive the larger brakes with the same accuracy / bias.
Old Apr 26, 2005 | 04:51 AM
King Tut's Avatar
King Tut
I believe they are the same size, and if the Enthusiast brake master cylinder can drive my Stoptech 14" 4 wheel kit, I think it can handle the puny Brembos.
Old May 6, 2005 | 06:33 AM
arizzee's Avatar
arizzee
As far as I've been able to research (using online Nissan parts catalogs), here are the differences:
There are two master cylinders available, 1). for the Base Model, 2). for all other models.
There are three different brake boosters; 1).for the Base model, 2). for the Track model, 3)for all other models.
So what affect would the different brake booster have?
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
