Brake Dust is Driving Me Crazy
Old May 24, 2005 | 06:44 AM
peterr's Avatar
peterr
Default Brake Dust is Driving Me Crazy
Does anyone know where you can get some dust covers or shields for my wifes Z? I'm getting real tired of washing 'em off each weekend.We put new pads on it at 15,000 but that didn't seem to help. Any ideas?
Old May 24, 2005 | 06:50 AM
mgk65's Avatar
mgk65
Replace the pads with Hawk HPS pads. Low dusting and easier cleanup. I got mine from www.tirerack.com
Old May 24, 2005 | 06:57 AM
SvR350z's Avatar
SvR350z
just use wheelwax. Thats all you got to do.
Clean your wheels, Remove the brake dust. Then you apply the wheelwax, I took my wheels off to do it but you dont have to I dont guess.
I applied to the inside and outside of rim.
It used to take 10 or more minutes each for my front rims to get clean.
Now it doesnt take 2. Its really good stuff.
Old May 24, 2005 | 07:00 AM
zand02max's Avatar
zand02max
I have tried that it still dusts, just makes it easier to clean. Only way to get around low dust is Hawks, ect. But you take the chance of squealing at low stops.
Old May 24, 2005 | 07:05 AM
SvR350z's Avatar
SvR350z
Well yeah,
You are still going to get the brake dust unless you change pads but if it just washes right off then its not really that big of a deal.
Either way will work, I just find it easier and perhaps a little cheaper to slap a little wheelwax on there and be done with it.
Once My brakes wear out then yeah, Ill replace them with something else.
Old May 24, 2005 | 07:29 AM
tware's Avatar
tware
I have brake dust *inside* the car. The door jams also build up quite a bit of dust.
Old May 24, 2005 | 07:34 AM
BigMoeTaki42's Avatar
BigMoeTaki42
You can either wax your wheels to make the dust easier to wipe off or get new pads to reduce dust altogether.
Old May 24, 2005 | 08:32 AM
ZPirate's Avatar
ZPirate
Wheelwax is good (I use it), but no substitute for less dusty pads. The OEM pads are terrible. I recommend Hawk HPS pads too.
Old May 24, 2005 | 08:48 AM
tware's Avatar
tware
I'm not that impressed with Wheel Wax so far. Its not much better than using plain old NXT on the wheels for me.
Old May 24, 2005 | 11:40 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Hey, since brake squeal came up in this thread, let me ask something:
In a MT how do you stop break squeal in the short term?
In my AT Maxima I hold the brakes down while stomping on the gas. This stops the squealing...but this technique works because the torque converter won't allow me to hurt any gears by doing so.
But...
what can you do in a MT to stop squeal without putting stress on the tranny and drivetrain etc?
Old May 24, 2005 | 12:35 PM
G352NV's Avatar
G352NV
I have the HAWK and have no dust, or very little. WELL worth the money!
Old May 24, 2005 | 12:39 PM
pulpz2's Avatar
pulpz2
Hawk HPS.
Old May 24, 2005 | 01:01 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
So Hawk HPS will reduce dust, that's a given...
how are they at reducing squeal?
Old May 24, 2005 | 01:14 PM
THENUTZ's Avatar
THENUTZ
They ADD squeal in a lot of cases - not reduce it... Brake dust is a contant battle and every solution seems to entail a compromise...
Old May 24, 2005 | 01:47 PM
slaponte's Avatar
slaponte
I had Axxis all around (non Brembo) and dust was reduced a lot. Due to a major redo of the brakes I recently switched to Hawk HPS. The Axxis I had installed by somebody and they squealed all the time. The Hawks I installed myself, no noise at all so far.
Brake pad noise is on the install, not the pad.
Old May 24, 2005 | 01:48 PM
pulpz2's Avatar
pulpz2
hmmmm.........I've not experienced any squeal what so ever. I used the shims that came with the pads and some of tha blue anti-squeal stuff.
Old May 24, 2005 | 03:20 PM
Strife350z's Avatar
Strife350z
hawks
no squeal here either... I think the secret is using the stock shims + antisqueal compound
anyway the method I use to keep my rims clean now is: hawks + crystal guard on the wheels once a summer + a mini california car duster every couple of days = NO DUST EVER and NO MORE WHEEL WASHING!
Old May 24, 2005 | 04:19 PM
JoneZZZ's Avatar
JoneZZZ
Originally Posted by Strife350z
hawks......no squeal here either........
+1 on the Hawks, and no squeal.....no dust problems(like stock).
Old May 24, 2005 | 04:29 PM
JCat's Avatar
JCat
+2 This was my first mod in 3/2004. The car was 2 weeks old.
The Hawk pads are easy to install. Do it!!!
Old May 24, 2005 | 05:28 PM
JokerDev's Avatar
JokerDev
+3..Hawks with anti squeal spray and shims. No probs whatsoever and much less dust
Obadabot
Jun 18, 2023 11:31 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
