Anybody have 14" stoptechs on Volks?
Old May 25, 2005 | 07:01 AM
D@ActiveTuning's Avatar
D@ActiveTuning
Default Anybody have 14" stoptechs on Volks?
More specifically SF Challenges? I haven't had time to measure everything out, but if it's been done before it will save me the trouble. I just need to know whether or not the brakes will clear 19" (19x8 21mm 19x9 23mm) Volk SF challenges.
Any help would be appreciated!
Old May 25, 2005 | 08:03 AM
bwzabodyn's Avatar
bwzabodyn
EVERY BBK will fit under any front Volk wheels that have the offset listed in Column A on the spec chart - and your wheels are under column A, so you have pretty much freedom of choice... what BBK's are you looking at?
Old May 25, 2005 | 08:06 AM
thawk408's Avatar
thawk408
I am pretty sure they will fit. Here is a picture with that setup on a Z.
http://community.webshots.com/photo/...53143903CUrpUr
Old May 25, 2005 | 08:26 AM
D@ActiveTuning
What chart are you looking at?
I am going to do the 14" Stoptech kit all around.
http://community.webshots.com/photo...353143903CUrpUr
Awesome, thanks for that! That's assuring, but I'd like to be positive hearing from either the owner of the same setup, or if bwzabodyn has a chart of fitment applications that'd be sweet!
Old May 25, 2005 | 08:47 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Like stated, the offsets will probably play the biggest role in BBK clearance. Check your offsets and specify whether or not you have "face 1" or "face 2" and then go from there by calling Mackin Industries directly for support
Good luck
Old May 25, 2005 | 08:53 AM
D@ActiveTuning
Good luck
I posted my offsets in my first post...21mm and 23mm front/rear
Old May 25, 2005 | 08:56 AM
MethodRN's Avatar
MethodRN
For Sale
The application chart is on the volk/makin website. You shouldn't have any issues.
Old May 25, 2005 | 09:06 AM
D@ActiveTuning
Ok cool, one more question...what's the overall opinion on slotted vs slotted AND cross drilled? From what I've heard cross-drilled has a tendency to crack...is that the case? Also that wouldn't be covered under warranty....
Old May 25, 2005 | 09:09 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Sorry! I am at work and I try to fly through posts
Old May 25, 2005 | 09:10 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Cross-drilled to my understanding tends to run a higher risk of cracking, but if you are keeping it on the street and not tracking, you should be fine. I run slotted & cross drilled on my 14" front and rear and they are still good after a few track events
Old May 25, 2005 | 09:12 AM
D@ActiveTuning
Ok perfect, thanks for your help
For anybody else's reference the clearence room on my wheel (19x8.5 19x9.5...I accidentally wrote 8 & 9 before) is 63mm and 86mm
Old May 25, 2005 | 09:47 AM
King Tut's Avatar
King Tut
This is the chart they are talking about:
http://www.rayswheels.co.jp/cgi-bin/...?modelName=SFC
Remember column A only guarantees clearance of the stock Brembo setup, not a 14" Stoptech kit. I wouldn't worry about the fronts, but the backs might be tight. I know I only have 3 mm of clearance on my rears with a 19x9.5 +24 GT-7.
Old May 25, 2005 | 10:15 AM
tig488's Avatar
tig488
narkotic has the 4 wheel stoptech BBK with 19" sf challenges, PM him.
Old May 25, 2005 | 12:21 PM
D@ActiveTuning
Thanks for your help guys, now you've got me worried on the rears!
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
