Springs that SLAM...
Old Jun 4, 2005 | 03:13 PM
EvL350Z's Avatar
EvL350Z
Default Springs that SLAM...
Sup guys...i want to "SLAM" my car with some aftermarket springs...dont know what to get...any suggestions...thanks...
Old Jun 4, 2005 | 03:46 PM
EvL350Z's Avatar
EvL350Z
Does HKS make Springs for the Z...if so has anyone used them...?
Old Jun 4, 2005 | 04:40 PM
mario60185's Avatar
mario60185
Chicago Realtor
sprint
Old Jun 4, 2005 | 04:48 PM
tig488's Avatar
tig488
ive got some KGMM supersport springs that lowered mine about 1-1.25 inches all around, with a pretty good ride, for sale real cheap.
Old Jun 4, 2005 | 05:00 PM
GQ 350z's Avatar
GQ 350z
Vogtland (sp) slams it, H&R, Tanabe GF210's
Old Jun 4, 2005 | 05:37 PM
manofsteele2003's Avatar
manofsteele2003
The Eibach Sportlines will drop it about 2"
Old Jun 4, 2005 | 07:09 PM
Zexy's Avatar
Zexy
Don't ever buy sprints please.
Tanabe GF springs give the BEST DROP.
Old Jun 5, 2005 | 08:03 AM
xsmallpaulx's Avatar
xsmallpaulx
hes right dont buy sprint they claim a 1.75" dropp but when i installed them they didnt even drop the car and inch. the springs that give you the most drop is not tanabe. its H&R. i have them on my car and they drop the car 1.5" all around.
Attached Thumbnails Springs that SLAM...-img_0020-vi.jpg   Springs that SLAM...-img_0024-vi.jpg   Springs that SLAM...-picture-016.jpg   Springs that SLAM...-picture-017.jpg
Old Jun 5, 2005 | 08:42 AM
Kaitain's Avatar
Kaitain
Did you guys that dropped your cars just by changing the springs also have to do some camber fix?
Old Jun 5, 2005 | 09:04 AM
pyindeem's Avatar
pyindeem
Default Yes.
camber fix will help your tires to last a bit longer. but if you want a nice drop& if you're on a budget. just do the spring. and save up $ for next set of tires. And depends on what tires you'r going to use..treadware..blah blah.. most tires with "budget drop" should last you about 10k miles (max), IMO if you're not planning to keep the car ,then this is the best way to go.
Old Jun 5, 2005 | 09:16 AM
GQ 350z's Avatar
GQ 350z
Yeah whereas the Tanabe's drop is nice and low, its also decently comfortable. I'm going to be buying the H&R springs b/c I want it lower and dont need coilovers.
smallpaul, were you able to get camber back in spec? Are you on 20's? can you describe you ride quality etc. ? is the documented drop actually given? On 19's would i slightly tuck or no?
ravi
Old Jun 6, 2005 | 08:47 PM
tommygunz's Avatar
tommygunz
Yeah guys, I'm also looking at the H&R springs only to drop my car but am also wondering about the camber......especially to avoid another feathering issue.
thx.
Old Jun 6, 2005 | 08:49 PM
tommygunz's Avatar
tommygunz
BTW....I'm putting 19's on my car.
Any info is well appreciated.
Old Jun 7, 2005 | 05:09 AM
Alberto's Avatar
Alberto
Cranky FI Owner
thx.
For the front I wouldnt really worry about camber, I never had any serious feathering issues and slammed a little over 2" and with negative 2 degrees my tires lasted me 25K miles. But if you did want to help your front camber about .5 degree more positive you could go with some of the front control arms offered from Kinetix, Hotchkis or 350 Evo, you'll have to decide if its worth it to you. On the rear I would recommend www.iapdirect.com for their rear camber/toe kit, it consists of larger eccentric bolts for toe and camber arms I have these I like it better than the Kinetix arms for rear camber/toe adjustment, which I also have. Good luck with your suspension
Old Jun 7, 2005 | 05:39 AM
tommygunz's Avatar
tommygunz
Thanks for the info Alberto.
Old Jun 7, 2005 | 12:20 PM
tommygunz's Avatar
tommygunz
As far as I know, H&R only make one set of springs for the 350Z. They're suppose to give you 1.1 drop in the front and 1.3 in the rear. How did yours end up 1.5 all the way around?......Just curious that's all.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
