willwood brakes
Old Jun 17, 2005 | 01:21 PM
glogan's Avatar
glogan
Default willwood brakes
Can I get pros and con on these kits and if they're a good buy?
Precision Brakes Company Front Kit #1: $1729.00
This kit would include Precision Brakes Company 14" x 1.25" 2 Piece Rotors (which come zinc plated and can be ordered plain, cross drilled, slotted, or cross drilled and slotted at no additional charge,) Wilwood Forged Superlite
4 Piston Calipers, Wilwood Polymatrix "Q" Compound Pads, Stainless Steel Flex Hoses, all necessary hardware, brackets, instructions, etc., needed to install the kit on your vehicle.
Precision Brakes Company Front Kit #2: $1599.00
This kit would include Precision Brakes Company 14" x 1.25" 2 Piece Rotors (which come zinc plated and can be ordered plain, cross drilled, slotted, or cross drilled and slotted at no additional charge,) Wilwood Forged Dynalite
4 Piston Calipers, Wilwood Polymatrix "Q" Compound Pads, Stainless Steel Flexlines, all necessary hardware, brackets, instructions, etc., needed to install the kit on your vehicle.
The difference in Kit #1 versus Kit #2 is the calipers. The calipers in kit #1 are the Wilwood Forged Superlite calipers. The calipers in kit #2 are the Wilwood Forged Dynalite calipers. The main difference here is that the Superlite calipers are bigger and wider, but the piston size is the same.
Thanks Guys and Gals
07ZEKE
Aug 23, 2021 09:15 PM
samansharif
Sep 25, 2015 12:31 PM
