New NISMO bushing kit ...
Originally Posted by Jason@Performance
I finally got them listed online!
NISMO Bushing's for 350Z / G35
See the above link for Pricing...
We have a few sets instock ready to ship...
jason@performance
might be interested in the rear upper shock mount bushing (item 56218-RRZ30 on your website) if they would work with aftermarket dampers.
let me know either here or PM and I'll add it to my current order.
thanks
thanks
Originally Posted by fairladyZ in Japan
Here is some more info from NISMO .. including # pieces, total part cost, and estimated install time ..
Front upper link bushing .. 4 pieces .. 1.5 hours
Front transverse link bushing ... 2 pieces .. 1.5 hours
Rear upper arm bushing ... 4 pieces .. 1.5 hours
Rear radius rod bushing axle side ... 2 pieces .. 4.0 hours
Rear radius rod bushing body side ... 2 pieces .. 1.0 hour
Rear front lower link bushing axle side ... 2 pieces .. 4.0 hours
Rear front lower link bushing body side ... 2 pieces .. 1.0 hour
Rear rear lower link bushing body side ... 2 pieces .. 1.0 hour
Rear shock absorber - upper bushing ... 2 pieces .. 0.5 hour
Total cost for parts is ... JYE 28,200 = US$ 256
Total estimated labor hours are ... 16.0 hours
I will be getting this NISMO bushing kit done in August together with a new tire install and then complete alignment.
This should be fun ...
Performance Nissan
Performance Nissan
Originally Posted by KhanMan
Want to update that link please?
http://mynismo.com/products/?id=5348
Performance Nissan
Performance Nissan
Originally Posted by palepony
jason@performance
thanks
thanks
If they are a direct replacement like Koni or Tokico shocks then yes they will work... Should work with coil overs as well, but I do not think they have that much travel...
Jason, do you have a part number for #16? I stripped the bolt on it today trying to install the Hotchkis sways and it may be easier to replace the whole thing than get someone to cut the bolt off.
Performance Nissan
Performance Nissan
www.performancenissanfactoryparts.com
With my new Cusco RS LSD, I'm getting a lot of drivetrain shudder when it's hot (just after a Solo2 run) or when I'm slowly engaging the clutch in a tight turn.
Any ideas of what bushings I should replace to keep the tranny from shaking?
