New NISMO bushing kit ...
Old Jul 23, 2005 | 09:57 PM
fairladyZ in Japan's Avatar
fairladyZ in Japan
Default New NISMO bushing kit ...
Introduced a few weeks ago in Japan ...
I posted information under the 350EVO new product release thread .. since it is related.
https://my350z.com/forum/showpost.ph...5&postcount=30
Old Jul 23, 2005 | 11:58 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Subscribing. Interested in hearing more about these. Please keep us posted...
Old Jul 24, 2005 | 02:27 AM
pimp1911's Avatar
pimp1911
+1. Standing in line with cash. Jason where you at? Chirp.Lol.
Old Jul 24, 2005 | 05:41 AM
alphaz's Avatar
alphaz
Subscribing
Old Jul 24, 2005 | 05:46 AM
ZBoater's Avatar
ZBoater
You know, under the Thread Tools command on the top bar, there is a "Subscribe to this Thread" command. Saves you from having to post to subscribe.
Oh, and by the way, subscribing...
Old Jul 24, 2005 | 08:07 AM
Gsedan35's Avatar
Gsedan35
What he said, but I need to figure out how to get past my wife's "mod" radar,.....hmm
Old Jul 24, 2005 | 08:24 AM
MIAPLAYA's Avatar
MIAPLAYA
I'm actually surprised it took NISMO this long to create one. The Sentra has had a Nismo bushing kit since its orginal parts were introduced. Priced around the same amount. It was a great mod when I had my Sentra. Handling was improved....
Old Jul 30, 2005 | 04:19 PM
FritzMan's Avatar
FritzMan
I've been waiting quite some time for something like this to come out. The stock bushings are quite soft.
Are these bushings harder rubber or polyurethane?
So, which vendor will be able to supply this for us?
Old Jul 30, 2005 | 06:37 PM
dklau33's Avatar
dklau33
Very nice. I would like to do this setup although it's a real pain in the a** to install. I had an Energy Suspension poly bushing setup on my previous car. My installer had to use a torch to get the old bushings out and then had to use a press to get the new ones in. Definitely not a short install. The labor of doing this stuff will you cost you more than the parts itself. But the benefits of getting rid of the suspension slop is well worth it for handling purposes. This in conjunction with a good custom alignment amazed me. Did a translation on the nismo page and this is the parts they listed where the bushings would be replaced.
Front upper link bushing
Front transverse link bushing
Rear upper arm bushing
Rear radius rod bushing axle side
Rear radius rod bushing body side
Rear front lower link bushing axle side
Rear front lower link bushing body side
Rear rear lower link bushing body side
Rear shock absorber - upper bushing
Old Jul 30, 2005 | 07:24 PM
fairladyZ in Japan
Here is some more info from NISMO .. including # pieces, total part cost, and estimated install time ..
Front upper link bushing .. 4 pieces .. 1.5 hours
Front transverse link bushing ... 2 pieces .. 1.5 hours
Rear upper arm bushing ... 4 pieces .. 1.5 hours
Rear radius rod bushing axle side ... 2 pieces .. 4.0 hours
Rear radius rod bushing body side ... 2 pieces .. 1.0 hour
Rear front lower link bushing axle side ... 2 pieces .. 4.0 hours
Rear front lower link bushing body side ... 2 pieces .. 1.0 hour
Rear rear lower link bushing body side ... 2 pieces .. 1.0 hour
Rear shock absorber - upper bushing ... 2 pieces .. 0.5 hour
Total cost for parts is ... JYE 28,200 = US$ 256
Total estimated labor hours are ... 16.0 hours
I will be getting this NISMO bushing kit done in August together with a new tire install and then complete alignment.
This should be fun ...
Old Jul 30, 2005 | 10:26 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Congrats! Let us know how it goes & what your thoughts are on the kit.
Old Jul 30, 2005 | 11:43 PM
sentry65's Avatar
sentry65
the burninator
so where do you buy the kit? Anyone?
Old Jul 31, 2005 | 04:22 PM
dklau33's Avatar
dklau33
I think so far it's only available in Japan. I presume someone will start selling them here in the states pretty soon.
Old Jul 31, 2005 | 05:41 PM
Gsedan35's Avatar
Gsedan35
www.Japanparts.com ,...................maybe? They not listed on japanparts web site to my knowledge. But maybe until Nismo USA get's around adding them to the U.S. lineup they can get them.
Old Jul 31, 2005 | 08:39 PM
psychoticminds1's Avatar
psychoticminds1
Subscribing ;-p
Old Aug 1, 2005 | 10:21 AM
daveh's Avatar
daveh
Has anyone contacted energy suspension to make an application for the 350Z? I believe all they need is some of the stock bushings and they can have a kit released very quickly. They're fairly inexpensive too.
Old Aug 1, 2005 | 10:31 AM
sentry65's Avatar
sentry65
the burninator
I talked with Jason@Performance and he said the Nismo bushing kit is still being tested so it's not going to be released for a little bit
Old Aug 1, 2005 | 10:32 AM
kybluez's Avatar
kybluez
not totally clear on this.....I'm I correct in stating that this is basically a way to get crisper handling from the stock suspension and it doesn't apply to aftermarket suspension upgrades or the nismo suspension upgrade or is this an upgrade you should do regardless of what suspension you have?
thanks
Old Aug 1, 2005 | 10:33 AM
sentry65's Avatar
sentry65
the burninator
it's seperate from the suspension - it's the joint pieces that connect the suspension parts to each other
