Has anyone tried installing rear springs only?
Old Jul 29, 2005 | 09:25 PM
asu174's Avatar
asu174
Default Has anyone tried installing rear springs only?
I'm satisfied with the front end drop, but I need it to go down another inch or inch and a half in the rear.
Old Jul 30, 2005 | 12:54 AM
sokudo9l6's Avatar
sokudo9l6
i wouldn't just lower the rear...your front and rear will not have the same spring rate.
Old Jul 30, 2005 | 04:43 AM
froggy's Avatar
froggy
I was wondering the same thing...
Front/rear don't have the same spring rate
I ordered the Hotchkis springs, and i'm planning to install the rear only(garage access+to compensate the lack of spare tire+look)
https://my350z.com/forum/wheels-and-tires/125762-lower-the-back-only.html
Old Sep 18, 2012 | 04:35 AM
Z-Sam's Avatar
Z-Sam
Any more info on doing this?
Just installed my new wheels. 19x9.5" ET 20 squared
With 255-35 & 275-35 tires.
Front sits ok but rear could be lowered by 1". I dont track. Just a DD.
Old Sep 18, 2012 | 04:59 AM
terrasmak's Avatar
Spring mount mod , its for you.
Old Oct 28, 2012 | 08:29 PM
Z-Sam's Avatar
Z-Sam
Just did the rear spring mount mod. Since the mounts were lil worn. Managed to lower only 15mm (.6"). Still feel the rear could go another 1" to be flush to be in level with the fender -wheel top.
Dont track the car just daily. Dont want to spend on coilovers. Seriously considering using the H&R lowering springs in the rear only. Which can give me the desired 1" drop.
BTW The car is a 2007 model.
Old Oct 28, 2012 | 10:21 PM
terrasmak's Avatar
Why would you want the rear lower than the front? The Prerunner look is for trucks, not cars.
Old Oct 28, 2012 | 10:50 PM
Z-Sam's Avatar
Z-Sam
Have a look at the pic again. The rear currently sits about an inch higher that the front. The shadow in the wheel well makes the difference seem less than it actually is.
I just want the rear to be level with the fornt & not lower.
Old Nov 3, 2012 | 11:47 AM
2000atlanticgt's Avatar
2000atlanticgt
I think it looks fine as it is myself. Nice looking ride.
Old Nov 6, 2012 | 12:19 PM
Phenom's Avatar
Phenom
Toasty
Despite the stock front spring rate being different from the rear, I would imagine swapping the rear out and not the front (or vice virsa) would alter the front:rear spring rate ratio to a number that the car rather not be at. This is just an assumption though as I've never considered changing the front or rear to aftermarket while leaving the other one stock.
Old Nov 14, 2012 | 12:37 AM
Resmarted's Avatar
Resmarted
I wouldn't advise doing just the rears. I have been planning on doing just rears but I have a rather unique set of requirements I need to meet.
Putting hotchkis in the rear (which are some of the softest rear springs out there, if not the softest) will make the car bounce. This is something I want/need for my car, but I'm looking to move the car back on it's haunches as much as possible (for my big turbo setup). On a street car, that isn't a good thing. I am broke, and need to hook up close to 1000hp, and I need max clearance at the front because my turbo hangs low. Not exactly a normal situation. Again I wouldn't recommend it. And I imagine that you'll get premature wear probably on the dampers or elsewhere. Spring mount mod, full set of springs, coils, or get over it. You may be able to find a spring mount that's newer and or cut shorter that would satisfy your urges. Maybe look for a set of springs that's close to oem spring ratio. Even then you may see premature wear/failure.
Old Nov 16, 2012 | 08:58 PM
ronn1's Avatar
ronn1
You can go another inch in the rear with Eibach Prokit..rates are very good and close to stock. However...you're now going to 1.6" total..that's LOW and will require camber arm mods. Also...you should go with them in front if you do that. Having said this....I would use an intermediate solution. Put stock rear mounts back (or maybe cut only .2" off at most) and then add Prokits. You would then avoid having to deal with camber arm mods and even leave the front alone.
hulkout
Apr 28, 2017 09:00 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
