NISMO Race Spring Set Touring 2 SCCA 350Z
Old Oct 13, 2005 | 07:58 PM
Goofy1477's Avatar
Goofy1477
Default NISMO Race Spring Set Touring 2 SCCA 350Z
Does anyone know much about the NISMO Race Spring Set Touring 2 SCCA for the 350z? Does anyone have these? How do they compare to the NISMO S-Tune suspension? Would it be better to get these springs and some other shocks? Any help would be appreciated.
http://performancenissanparts.com/ca...oducts_id=2591
Old Oct 13, 2005 | 08:41 PM
palepony's Avatar
palepony
goofy
i would ask you next.. what do you want to use your vehicle for? the nismo T2 SCCA springs have very high spring rates. i would argue that they would be for track use only, but i guess to each their own.
in comparison to the s-tune, they are nearly double the spring rate.
ideally, they would be matched with competition shocks or revalved off the shelf shocks, although some have run with off the shelf koni sport yellows. look to the autox/road race part of this forum for experience with these. i do not own them.
pp
Old Oct 13, 2005 | 10:59 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
very stiff compared to the NISMO S-Tune suspension...
the spring rates on these springs are more just a little bit less then TEIN FLEX in the front and MORE then TEIN FLEX in the rear!
Old Jun 2, 2006 | 08:39 PM
1cockyZ's Avatar
1cockyZ
how much do these lower the rear of the car
Old Jun 2, 2006 | 09:13 PM
Gsedan35's Avatar
Gsedan35
Nismo T2 350Z Linear springs 1”/1” drop on 350Z
Far too stiff for use with anything but revalved Koni shocks or http://www.tcklineracing.com/nonbmw.htm
Listed for information ONLY!
Spring rates in LBS 625/700
Stiffer then oem by F+99% R+105%
Nismo S-tune (twin tube construction, uses progressive springs, especially in rear)
350Z/G35 Coupe
Spring rates 448/504
Stiffer then oem by F+43% R+48%
Unitech/truechoice coilovers
500/425
Stiffer then oem by F+60% R+24%
JjL
East Canada
Jun 12, 2019 03:04 AM
davidm350
Oct 31, 2015 02:28 PM
Paul.
Oct 16, 2015 07:34 PM
CJs_Z33
Sep 18, 2015 12:06 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
