Brembo Rotors Warped
Well I just feel stupid my brembo rotors are warped, is there any way possible to resurface the stock brembo rotors? Is it even a good idea to try to keep them or should I just upgrade(I'd rather not spend money on rotors if i dont need to)? I will be running 500+rwhp within the next few weeks.
Performance Nissan
Performance Nissan
yes you can resurface if you have enough left on them...
http://performancenissanparts.com/ca...mbo+aero+rotor
I spoke to Jeff at Stoptech and pretty much rotors never warp
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Uneven pad deposit are almost as bad as a warped rotor....they will manifest vibrations, squealing, pulls to one side, etc...
sometimes the only cure is to have them turned (there are a couple of tricks to try and cure this, but doesn't always work)
always bed them properly when new... both pads and rotors
I learned the hard way... I have ****ed up a rotor with a single drag strip run...
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
