Advice on next suspension upgrade
Old Nov 9, 2005 | 09:29 PM
visionboy's Avatar
visionboy
Default Advice on next suspension upgrade
I currently have a 2005 roadster with 19" rims and Eibach Pro Kit. What is the next best upgrade to do? Should I go for sways? Add Shocks? or how about replacing my current springs with Tein Basic Coilovers. Any advice is appreciated. Thanks
Old Nov 12, 2005 | 07:37 PM
alininger2001's Avatar
alininger2001
Sway bars. The suspension set up in the Z is pretty good. The best handling Z I know of is running hotchkis sways and 275/40/18 tires on all four corners. It averaged over 1g on the skidpad on street tires! Read this article it may help with your decision.
http://www.sportcompactcarweb.com/pr.../0404scc_350z/
Old Nov 12, 2005 | 07:45 PM
zland's Avatar
zland
Sport Z Magazine
Interesting read....
Old Nov 12, 2005 | 08:27 PM
alininger2001
Do you think that would be a good setup. I am always looking for advice from the pros. Some magazines get it right and some don't. That setup does sound pretty mean though.
Old Nov 13, 2005 | 04:12 AM
palepony's Avatar
palepony
visionboy
what do you do with your car? that will help in what you do next.
pp
Old Nov 13, 2005 | 05:23 AM
alininger2001
Mostly it's a daily driver. On weekends I like to take it on curvy country roads. I eventually want to take it out for some track days at texas world speedway, maybe do a little autocross.
Old Nov 14, 2005 | 11:51 AM
visionboy's Avatar
visionboy
Originally Posted by palepony
visionboy
pp
it's just a daily driver..i don't track or anything, but i do want to improve on the handling...i feel like there's to much body roll. If i go with Hotckis sways, should i go ahead and get the TVS kit or will the ways work good with my eibach pro kit?
Thanks for all the replies and help guys ...
Old Nov 14, 2005 | 11:52 AM
visionboy's Avatar
visionboy
Hey what's up? you're from houston too? you should come to our 350z meets sometimes and chill..its fun!
Old Nov 14, 2005 | 12:13 PM
RedLeader's Avatar
RedLeader
visionboy-
I bought Hotchkiss sways before I swapped anything else out and can confirm they made a big improvement. That would be my next move. Then I installed JIC coilovers and I just swapped those out for Tein Flex w/EDFC. If you like your ride height with the Eibachs, you should check out Koni adjustable shocks. Ted, the owner of Scott Performance, told me he tracks his roadster and he really likes Eibachs and Konis together.
Good Luck,
Bruce
Old Nov 14, 2005 | 04:21 PM
alininger2001
Sure, just say when.
Old Nov 14, 2005 | 04:35 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Understand that everything is a trade-off. When they tested this car in the rain, out of 11 cars, it only scored higher than a car that did not run.
Chris
Old Nov 14, 2005 | 06:10 PM
alininger2001
I did read that article, but it barely ever rains here and I tend to take it easy in the rain.
Old Nov 14, 2005 | 06:17 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
sway bars without a doubt
We use and recommend Cusco
Old Dec 22, 2005 | 09:09 PM
visionboy's Avatar
visionboy
Hey guys thanks for all the replies...I finally got the Hotckis sway bars, but the installer put the settings at Hard front /Hard rear... drive alot better but a little rough at times. is this safe? What is the recommended settings? esp for roadster..thanks
Old Dec 23, 2005 | 05:02 PM
djbit's Avatar
djbit
I think the recommended setting from folks here is medium/medium. I'm doing the Hotckis TV set up this weekend...
Old Dec 23, 2005 | 07:45 PM
Badfish25's Avatar
Badfish25
I have hotchkis sways and springs, I originaly had them on Med/med but found I had to omuch oversteer, I ended up driving the car slower around corners, especially after I lost the back end once on a highway onramp.
Now I have it set up hard front medium rear....BIG improvement, front has alot more "bite" and nearly no roll anymore, Handles great, awesome balance.
Old Dec 24, 2005 | 01:07 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Sway bars for sure!@ I have mine set at Hard front...medium rear
Old Dec 24, 2005 | 08:39 AM
visionboy's Avatar
visionboy
thanks guys, i will change my to Med/rear ...and yes i can definitely tell a difference with just the sway bars on. Thanks for all the advice
