How do I take off front Coilovers?
Old Nov 11, 2005 | 05:31 AM
pj550v12's Avatar
pj550v12
Default How do I take off front Coilovers?
I recently had coilovers put on but I need to swtich back to stock and sell my JICs because of money reasons. I had a shop put them on, but I'm fairly confident I can take them off and put the stocks back on I just need a little bit of guidance. I'm going to be doing this in my driveway with basic jacks, jackstands, compressor etc. What I dont have is a spring compressor, is the job still doable?? Any help would be appreciated, remember, its only the front I need to do, I already did the backs on my own. Thanks in advance.
Old Nov 11, 2005 | 06:07 AM
westpak's Avatar
westpak
SFZCC
If you still have you stock shock/springs assembled then you do not need a compressor as you will remove one assembly and install the other, you can do it yourself easily if that is the case, just disconnect the shock at the top and bottom, you will probably have to disconnect the lower control arm to easily remove the shock.
Old Nov 11, 2005 | 06:28 AM
pj550v12's Avatar
pj550v12
Thanks for the quick reply. Will I need to put some sort of stand underneath the shock? I guess what I'm asking is, after the car is jacked up, will there still be pressure from the spring that I need to be careful of?
Old Nov 11, 2005 | 12:22 PM
pj550v12's Avatar
pj550v12
bump
Old Nov 11, 2005 | 01:01 PM
westpak's Avatar
westpak
SFZCC
Not for the front.
Old Nov 11, 2005 | 02:21 PM
pj550v12's Avatar
pj550v12
Awesome, thanks again. I'll let you know tomorrow how it comes out.
Old Nov 11, 2005 | 03:49 PM
westpak's Avatar
westpak
SFZCC
Have fun, when the car is jacked up and the front wheels up in the air the shock is extended so no pressure on the spring, the reason I said you might want to remove the lower arm is because it is tough to compress the shock/spring specially with the stock shocks that have longer springs.
The rear need something under the spring because those are under pressure.
Old Nov 12, 2005 | 12:15 PM
pj550v12's Avatar
pj550v12
Was a piece of cake. I actually removed the upper arm, it seemed like the easiest way for me. The first side took a little while trying to think everything out, then the second side took no more than 25-30 minutes to take coilover off and put on the other one, thanks for the help!
Obadabot
Jun 18, 2023 11:31 PM
