Changing brake pads...
Old Dec 4, 2005 | 01:47 PM
Mr.Jadkowski's Avatar
Mr.Jadkowski
Originally Posted by slaponte
Hawk pads, no dust, no squeal.
I use a brake quieter "glue", is a blue spray you cover the back of the pads with, let it dry to a "tacky" feel and then you put them on. Been using this for years (a can goes a long way), never had a break squeal on me. (Why mess with sucess).
I would say the brand but I am at work...
Wierd... so this goes between the back of the pad and the shims? I just used some high-temp grease between the pad and the bottom shim, and the bottom and top shim, and then a little bit on top of the top shim. I guess glue would work in the opposite way of the grease, instead of allowing the shim to move it would hold it still. Never even thought of that.
