Best Coilover and Sways for oversteer/drift/semi track use
Old Jan 11, 2006 | 02:37 PM
zillinois's Avatar
zillinois
Originally Posted by anotheraznguy
silkroad is great w/ the 240sx community but no one has tried them out on the z as of yet
Where can I find the specs on the Silkroad for the 350z? I searched google, but didn't come up with anything.
Old Jan 11, 2006 | 03:08 PM
636Racer's Avatar
636Racer
apparently so, as well as the AE86 guys too. A friend of mines is has it in his AE86 - featured in www.silkroad-usa.com - and has sponsored a set of RM/A8 for me to use in the G35. I just need time to install them. I'll post pics of them tomorrow.
Old Jan 12, 2006 | 08:49 AM
Asterix's Avatar
Asterix
Originally Posted by zillinois
As for spring rates and car handling, the way I look at it, if you've got a near 50/50 car, rear drive, same spring rate and tire size on all 4 corners, you should be driving a pretty neutral car. That's the theory anyway. Very few of the other setups have the same spring rates all the way around.
Don't confuse the rate of the spring by itself with the spring rate at the wheel. The front and rear suspension may have different mechanical advantages, making springs with the same rates front/rear have different rates at the wheel. You want the front to have a higher wheel rate than the rear so the car doesn't drive funny. Someone on the board probably knows the divider to get from spring rate to wheel rate. I've not had time to measure it yet.
Asterix
Old Jan 12, 2006 | 09:18 AM
zillinois's Avatar
zillinois
Asterix
I agree, but most front motion rates are closer to 1 than the rear so the mechanical advantage is built in to the front. I don't know if anyone has calculated the exact numbers out yet though. That would be a good winter project for someone.
What is interesting though is that the Koni/Truechoice was higher in front and lower in the rear and that was the way I was headed (as mentioned earlier) if I would have kept the Basics or got a new setup. I wanted to drop the rear lower than the front. So I'm guessing that the rear has very high motion rate. This does not bode well for all of those guys who have 600+ lbs springs on the rear unless they want a tail-happy car.
Old Jan 12, 2006 | 09:20 AM
zillinois's Avatar
zillinois
Asterix
Sorry double post.
Old Jan 12, 2006 | 09:35 AM
636Racer's Avatar
636Racer
Asterix
unsprung weight and spring weight?
http://www.mirafiori.com/dave/s-terms.html
Old Jan 12, 2006 | 10:04 AM
zillinois's Avatar
zillinois
Is this a question?
Asterix is refering to the fact that there is a difference between compressing a spring on a spring tester (straight up/down motion) vs. compressing a spring on a suspension (arched motion and leverage). Compressing a spring on a suspension may change the practical spring rate.
Old Jan 12, 2006 | 10:19 AM
EnthuZ's Avatar
EnthuZ
I think I see a few typo's here that are confusing the discussion. Wheel spring RATE is very different from the unsprung WEIGHT of the spring. Most books use around 50% of the spring's weight as it's sprung/unsprung mass. My math skills are too poor to calculate the ratio's of the machine measured spring rates, to the actual wheel rates that vary with the springs distance from the center of the tire's contact patch do to the different leverages being applied. Wow, now I'm getting confused!
Old Jan 12, 2006 | 12:56 PM
xenonk's Avatar
xenonk
Originally Posted by Roggan
Acctually from the research ive been doing during the day the Zeals seams like the best coils you can get, best spring rate combo and I saw some very possitive feedback from owners, though i have no idea of propper price (saw some for $3000!?) and availability, where can you get them for the best price?
I guess since the Zeals have stiffer springs and are more biased towards the rear they would compensate for the sways, while adding additionally stiff sways would make the car too stuff and very "snappy".
If the Zeals are in the $3000 ballpark im clearly leaning towards ~$700 basics + $300 hotchkis sways based superior value and zillinios experience with this setup... Ive already booked up $6500+ to get a full JDM Nismo V2 bodykit with CF rear wing, so im not so keen on making it 10k so fast hehe
/Roger
call up Racecomp Engineering and tell them that Keefe referred you and they should be able to help you out from there
Old Jan 12, 2006 | 02:03 PM
636Racer's Avatar
636Racer
it was in question of trying to find out what he's trying to get at
Old Jan 12, 2006 | 04:05 PM
Roggan's Avatar
Roggan
Cool, thanks mate!
/Roger
Old Apr 15, 2010 | 08:49 PM
Goo$e's Avatar
Goo$e
Liar.
Old Apr 17, 2010 | 10:50 AM
tw8715's Avatar
tw8715
Originally Posted by MoodDude
I agree with the Tein and Hotchkis performance for the money. Yet, I have the Tein Flex with EDFC. EDFC makes it really easy to change from road to track with one touch of the button. For oversteer, look at your tires, our cars come set up for understeer. Just install same size wheels and tires all the way around and drive w/o your VDC on!
If you go with Hotchkis, look at the thread on this board for the shaft collar fix.
Do you have to race in the Snow in Sweden?
not to highjack thread lol but whats the shaft collar fix? how to do?!
Old Apr 17, 2010 | 12:21 PM
MethodRN's Avatar
MethodRN
For Sale
Originally Posted by goo$e
liar.
Originally Posted by tw8715
not to highjack thread lol but whats the shaft collar fix? How to do?!
holy thread revival batman!!!!!!!!!!!!!!!!!
Old Apr 23, 2010 | 06:34 PM
636Racer's Avatar
636Racer
haha...no sht, about the pics? never took pics of them in the box, they're on the car. i attempted to take a pic but it's too dark under the fender well.
maybe when i get a chance to get it back on the lift, i'll take pics then. until then, all can assume labeling me a liar.
hulkout
Apr 28, 2017 09:00 PM
