Crux vs Ohlins coilovers
Old Jan 28, 2006 | 03:55 AM
100122923's Avatar
100122923
Default Crux vs Ohlins coilovers
anyone have experience with either of the two? I have to make a decision
very very soon. any inputs would be greatly appreciated
thx in advance
Old Jan 28, 2006 | 10:08 AM
350Zteve's Avatar
350Zteve
thx in advance
You can't go wrong with Ohlins
Old Jan 28, 2006 | 01:17 PM
Jason333's Avatar
Jason333
hi
+1
I have had Ohlins on many bikes, they are really really nice pieces.
Old Jan 28, 2006 | 05:20 PM
MarquisDeSam's Avatar
MarquisDeSam
Good luck trying to get Ohlins. They are tuned by IMPUL, and the IMPUL/OHLINS coilover costs a GRIP. Crux does not compare to the quality of the ohlins unit. But i am dissappointed to see that the ohlins unit does not have an external reservoir... i would think with the price that's the least they would do...
Old Feb 23, 2007 | 08:22 PM
Kwame's Avatar
Kwame
Originally Posted by Gsedan35
Ohlins does not make a Z33 application nor do they have any intention of doing so. The Impal unit's are built under license with zero imput from Ohlin, so they have NO work from them to work out their valving science. I had a conversation with Ohlins about them and in so many words he said that "JDM stuff uses valving stiffness level's that we would never use". I have seen one fairlady Z33 running a set of custom Ohlin's, (see link below and pic). I would not waste a moment on the Impal's, JRZ has shocks for this car and a reputation that is in the same vane. You can also get Penske's and Moton's. Plus Tc Kline racing has some very nice custom valved Koni's that have independent compression and rebound adjustabilty for a very decent price per shock.
http://www.exvitermini.com/pd1z.htm
Not so fast grasshoppa...
http://www.z1auto.com/prodmore.asp?m...ng&prodid=2155
Old Feb 23, 2007 | 09:23 PM
Gsedan35's Avatar
Gsedan35
So when I call Ohlins USA again am I going to hear the same thing again as above, or are they going to say yes WE do make them now?
USA
Öhlins USA Inc.
703-C Old Spartanburg Road
Hendersonville, N.C. 28792
Tel. +1 828 692 4525
Old Feb 24, 2007 | 12:10 AM
Fingers's Avatar
Fingers
Wow, I was expecting the ohlins to be alot more money than that, is there more to this story or is that the usual going price for an ohlins car setup.
Old Feb 24, 2007 | 07:08 AM
betamotorsports's Avatar
betamotorsports
Although I can't speak for Ohlins, Penske works with independent chassis tuners to develop a lot of their applications. Its just a matter of bandwidth. They (Penske) don't have enough staff to do the necessary development work for all the possbile platforms. Most of Penske's staff is devoted to professional racing support.
I was involved with EMI Racing in the development of a Penske 8100/8760 setup for last two generations of Vipers. What EMI Racing developed is exactly what Penske sells (and pretty much anyone else who sells Penske's for Vipers).
Where? I would be very interested in seeing what was developed because I've started down that path for my own car. It would be nice to purchase instead of doing buttloads of development.
True. I've already dyno'd some Tien FlexRS shocks and I'm amazed at the amount of compression damping they run.
Old Feb 24, 2007 | 05:16 PM
Gsedan35's Avatar
Gsedan35
John, IIRC I became aware of the Penske's because awhile back (thinking early 04) I found a post on either SCCA forums or another 350Z board where this person had sold his Penske shocks in favor of another set that was more adjustable. It did not sound like he anything other then single person vs part of some organized shop. Moton's are avaliable for the car, but I'm sure your already aware of that.
Old Feb 26, 2007 | 06:59 AM
THE TECH's Avatar
THE TECH
Penske's FTW!
Old Feb 26, 2007 | 04:54 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yes they are through Ohlins USA
Old Feb 26, 2007 | 06:33 PM
Gsedan35's Avatar
Gsedan35
Nuf said Adam, thanks.
Old Feb 26, 2007 | 06:56 PM
Z1 Performance
Former Sponsor
we'll be putting them through their paces soon so I'll make sure to do a write up for those curious.
If they are anything like their Evo setups, we're going to be in really good shape I think
Old Feb 26, 2007 | 09:05 PM
Tubbs's Avatar
Tubbs
Comparison between Ohlin's and Zeals please!
Old Mar 25, 2008 | 09:52 PM
mistico's Avatar
mistico
Reviving this Ohlins thread instead of starting a new one...
My next upgrade will be suspension and the more I think about it, the more I change my mind. I was pretty set on Ohlins coilovers, but I don't see many people using them on track, and they are not made by Ohlins, but instead built under their license in Japan vs Sweden. The other downside is that they are only one-way adjustable. I talked a local shop and they are an authorized Ohlins service center and carry all the parts. They charge $45 per shock for a revalve, but still a pain to have to remove them.
This leads to other coilovers or going for a separate spring/shock combo. The 2-way koni's seem like a good shock as well. I know Penske has shocks avaialbale as well but they are all custom setups, and as far as I know, those shock are not built specifically for thre 350z by Penske.
I would like to get the Ohlins, but if I can get a better setup with a separate spring/shock combo I'll go that route.
My car will eventually turn into a 70% track car. I don't really care what the components look like either as long as they perform.
What I'm mostly interested in is, if my car will spend a good amount of time at the track(roadcourse), is Ohlins a good choice? I know the products that come from Sweden are excellent, but I have no experience with the ones built in Japan. Some say they are too stiff, others say the components are from sweden but built in Japan, some people here were supposed to give reviews but no one has, etc.
So does anyone know the "real deal" with the Ohlins DFV coilovers, or have all the discussions on the board been based only on specs?
Any new info would be appreciated.
Old Mar 26, 2008 | 01:31 AM
jdmrwd's Avatar
jdmrwd
I have been looking for more info about the DFV, how they ride, and perform. Since day one I bought my Z, but recently I came across a killer deal on a brand new set, so I went ahead and purchased it. I will probably shock dyno it and get some numbers for this board. But the built quality is just worth the money over other off the shelf coilovers i have seen.
Old Mar 26, 2008 | 02:57 PM
mistico's Avatar
mistico
Thanks.
If I go with coilovers, I def want the Ohlins. The TC Kline Koni's are half the price though w/springs.
Old Mar 29, 2009 | 11:40 PM
marcelz's Avatar
marcelz
crux......all the way
Old Mar 30, 2009 | 06:35 AM
warmmilk's Avatar
warmmilk
Originally Posted by mistico
Thanks.
really? where? i thought they were like 3k (same as the ohlins)
Stevo Z
Oct 3, 2015 09:14 PM
