Brake Dust or Rust?
Old Feb 7, 2006 | 07:21 PM
sundevil67's Avatar
sundevil67
Default Brake Dust or Rust?
I have this orange gunk on my rotors, and am wondering if this is rust or brake dust? Forgive me if the answer is obvious - I don't know much about brakes.
Thanks.
Old Feb 8, 2006 | 01:57 PM
steakpinoy's Avatar
steakpinoy
That should be rust. When you apply the brakes, the pads don't grip that small area of the brakes, so that it's free to rust. That's normal though.
Old Feb 8, 2006 | 02:02 PM
NissanZfan's Avatar
NissanZfan
yeah, its nothing to worry about......its normal.
Old Feb 8, 2006 | 02:16 PM
ANXIOUZ's Avatar
ANXIOUZ
/ignore
Old Feb 8, 2006 | 06:29 PM
sundevil67's Avatar
sundevil67
Default Brake Rust
OK, so all I have to worry about is it looking crappy? Any tips on polishing them? Is there a solution that removes the stuff safely? Am I being too ****?
Old Feb 8, 2006 | 07:11 PM
plumpzz's Avatar
plumpzz
itll come back *** soon as u polish it. since nothing is rubbing against it to scrap the rust off, rust is free to form there.
Old Feb 8, 2006 | 11:34 PM
reptile718's Avatar
reptile718
You can use some high temp semi ceramic paint (engine paint) around the areas that the pad does not touch. Just use some brake cleaner and wire brush to clean everything out. Tape up the areas that you do not want painted and spray away. Not only will it prevent rust but look a lot better then the old rusty rotor look you currently have. I went with black for my rotor hubs and a metallic silver for my calipers. I will have some pics up next week when I get a chance to clean the Z up. I will keep you posted so you get an idea of what I am talking about
Old Feb 9, 2006 | 10:19 AM
drumma022's Avatar
drumma022
In some cases, when you use semi-metallic pads that creat a lot of dust, you may notice more surface rust spots on the rotor, but as your drive the car daily they will wear off.
Old Feb 9, 2006 | 10:31 AM
sundevil67's Avatar
sundevil67
One thing that I left off was that I have only experienced this since I replaced the front brakes. Never noticed it when I had the stock ones. When these are ready to go, I will probably replace them with performance brakes. Any recommendations for some sweet looking, well performing, and reasonably priced brake kits? Are there any particular aspects of a brake brand that I should ask about when replacing them in the future? In other words, why did this particular brand collect so much rust and the stock ones didn't? With these rims, you can really see it, and it is quite ugly. Any advice?
Old Feb 9, 2006 | 10:34 AM
Say Rusty Rotors ten times fast. Bet you can’t do it.
Old Feb 9, 2006 | 11:27 AM
ANXIOUZ's Avatar
ANXIOUZ
Do you use any special wheel cleaner? Once when I was at the dealer my tech wanted to show me this stuff. It was amazing and made my rims shine like crazy. But then I noticed that the rotors turned orange-ish (i.e., a rust color) for a while. They eventually went back to normal but it was definitely the cleaning solution and it made me nervous.
Also, can you take a straight-on shot of the rims for me?
Old Feb 10, 2006 | 10:08 AM
dark_muppet's Avatar
dark_muppet
I got to 7 then totally fell apart.
Old Feb 10, 2006 | 11:09 AM
sundevil67's Avatar
sundevil67
Default Brake Rust
Old Feb 10, 2006 | 11:12 AM
ANXIOUZ's Avatar
ANXIOUZ
Damn, those look nice!
Sorry, I meant a pic of the discolored rotors straight-on.
<-- Please excuse the idiot.
Old Feb 11, 2006 | 10:12 AM
sundevil67's Avatar
sundevil67
I will try to take some more shots this afternoon - I think I am going to try to brush them off a bit today.
Old Feb 12, 2006 | 10:50 PM
sundevil67's Avatar
sundevil67
Old Feb 13, 2006 | 08:23 AM
ANXIOUZ's Avatar
ANXIOUZ
Oh, I see now. Hmmm. I'll try to take a pic of mine...it's somewhat similar but not quite.
It's nothing to worry about...it's just aesthetically displeasing. I don't know how you can undo that rust though.
As for replacement performance brakes, I think StopTech has the best bang-for-the-buck. The Brembo's from Nissan are like $4k or something ridiculous.
Old Feb 13, 2006 | 08:33 AM
taurran's Avatar
taurran
Buy some new rotors with coated hubs. Problem solved.
Old Feb 13, 2006 | 10:32 AM
sundevil67's Avatar
sundevil67
Is that what happened? I guess the brake shop that sold me the brakes (after assuring me that they were real good ones - they certainly charged me enough) forgot to mention that they would do this. The stock brakes certainly didn't.
Old Feb 13, 2006 | 11:00 AM
Kolia's Avatar
Kolia
Simple enough, your pads a chewing up your rotors...
Metalic pads will do that too...
