NEW Stance SUS Coilover Review
Old Sep 1, 2006 | 09:16 PM
  #201
skidmarq's Avatar
skidmarq
BUMP to find out if any of our sponsors would like some business this week. PM me a price on the coilovers...
Old Sep 2, 2006 | 08:15 PM
  #202
DMK's Avatar
DMK
Ok, so when using this coilover, we must keep the stock rear spring in place. And these coilovers will compress the stock springs? Will using an aftermarket rear spring help?
Also, what is the minimum height drop front/rear on these coilovers? And do the pillowball mounts come with an adjustable camber plate?
Old Sep 3, 2006 | 08:24 AM
  #203
twenzel's Avatar
twenzel
... No. You do not re-use the OEM springs in the OEM location or anywhere for that matter.
Old Sep 3, 2006 | 09:43 AM
  #204
jinsei888's Avatar
jinsei888
.......lol, no you TAKE OUT the old OEM spring...
Old Sep 3, 2006 | 09:45 AM
  #205
jinsei888's Avatar
jinsei888
I always dismount the rear suspension to get access to the rear adjuster dials; takes me 10 minutes per side
Originally Posted by dewuser
It doesn't look like we can easily access the "REAR ADJUSTER DIAL" from the top.
As mentioned that would require drilling thru the plastic outer-cover and the metal rear brace. (see pic below)
Anyone has a better idea?
Or should we always dismount the rear suspension to get to the "REAR ADJUSTER DIAL"
Old Sep 3, 2006 | 09:47 AM
  #206
jinsei888's Avatar
jinsei888
Originally Posted by daytona350z
it seems as though your rubbing your front tire on your fender well here.
rubbing is teh pimp!
Old Sep 3, 2006 | 05:40 PM
  #207
BloMyS14's Avatar
BloMyS14
^^I like it when the fender makes the tire smoke.
Old Sep 5, 2006 | 08:27 AM
  #208
dewuser's Avatar
dewuser
When using a true coilover systems like Stance or BuddyClub, the OEM rear spring must be removed. Optionally the OEM spring basket may be removed when installing an after-market control arm.
Here is a link with pictures of a true coilover system: https://my350z.com/forum/northern-california/209153-share-experiences-with-battle-version-camber-and-toe-arms-kit-pics-included.html
There is no minimum drop with the Stance coilover. The height is fully adjustable, so you can go higher than stock or slam your Z.
I've set my Stance coilovers to 1 inch lower than stock.
The Stance pillowball mounts does NOT come with camber plates. You may purchase adjustable control arms to correct camber & toe.
Again see link for details: https://my350z.com/forum/showthread.php?t=209153
Old Sep 5, 2006 | 01:53 PM
  #209
DMK's Avatar
DMK
Thanks a lot dewuser.
Old Sep 27, 2006 | 12:48 AM
  #210
DMK's Avatar
DMK
Can any owners give an update on these?
Old Sep 27, 2006 | 06:03 AM
  #211
three_fitty's Avatar
three_fitty
A bit soft for my tastes, but overall... they're great.
Old Sep 27, 2006 | 08:03 PM
  #212
DMK's Avatar
DMK
Can you be specific on what you don't like about them and what you would change?
Old Sep 29, 2006 | 10:36 AM
  #213
three_fitty
I just wish they spring rates were higher thats all. Its 12k front and 5k rear. I think a 14k front and 8k rear would be best. Springs are cheap anyways, you can get them from stance for 50 bucks a spring, and rate you want too.
Old Sep 29, 2006 | 07:18 PM
  #214
DMK's Avatar
DMK
Really? A couple pages back, some people wanted 10kg front 6kg back. So the stock springs are good for daily driving and occasional track use?
Old Sep 30, 2006 | 04:07 PM
  #215
Speezee's Avatar
Speezee
Default rear dampening adjustment
So when you dismount the rear coils to adjust the dampening, you have to get an alignment again, right? Or will everything be ok as long as you don't change the ride height?
Old Sep 30, 2006 | 09:47 PM
  #216
jinsei888's Avatar
jinsei888
No need to realign the rear. You only drop the three top strut mount bolts, then turn as you need and bolt the 3 right back up again; the 3 bolt points and 3 bolt holes on the strut fit snug, there is no alignment change after dismount/remount to adjust dampening ****
Old Oct 1, 2006 | 10:16 AM
  #217
skidmarq's Avatar
skidmarq
Some before and after shots...
Old Oct 1, 2006 | 02:35 PM
  #218
DMK's Avatar
DMK
Very nice. Reviews?
Old Oct 2, 2006 | 04:23 PM
  #219
skidmarq's Avatar
skidmarq
So far I'm very pleasantly surprised by the streetability of these coilovers. Yes, you can tell you aren't on your OEM suspension but only when going over extremely large bumps.
I took it for a spin on some back roads that had plenty of uneven pavement and going over bumps was not an unpleasant experience at all.
I'm saving my overall opinion until I get a chance to push them to their limits at PIR. After my next HPDE session, I'll put up a full review...
Old Oct 2, 2006 | 10:03 PM
  #220
brigz's Avatar
brigz
Cant wait to get mine in later this week. I will give a review after a bit of testing.
