got air in line while changing brake fluid (help)......
Old Feb 17, 2006 | 06:51 AM
Axelerate's Avatar
Axelerate
Default got air in line while changing brake fluid (help)......
when I was bleeding my brembo brakes, I got some air on the front right outside, I got all the air out of that side and then re-checked the inside bleeder and everything seems fine. I then bleed the left front inside and outside and no air was coming out.
My question is could and air of gotten to my rears also? I would of re-bleed them but I was running out of time and fluid. I wasnt sure if it was possible to of gotten air in rear lines form doing the front.
Old Feb 17, 2006 | 09:00 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
How do the brakes feel? If you have air you should have a mushy pedal.
Just be safe, get more fluid and re-bleed RR, RL, FR, FL in that order.
