Brake pad question
Old Mar 12, 2006 | 02:40 PM
iheartZ's Avatar
iheartZ
Default Brake pad question
hey guys how long did it take for you to have to replace the brake pads? im at about 10K and im hearing squeaking sounds. I know its not brake dust bc i cleaned the hell out of my wheels.
Old Mar 12, 2006 | 03:31 PM
Ztalker's Avatar
Ztalker
the front oem pads will last between 10K and 15K depends on the driver and road conditions. i changed mine at 16K and they were still good for another 3K but they squeaked during stops.
Old Mar 12, 2006 | 03:38 PM
r26's Avatar
r26
the stock pads have mad squeaking. i replaced mine with hawks and barely have any squeaking. but the stopping doesn't feel the same as stock. less bite.
Old Mar 12, 2006 | 04:06 PM
highside107's Avatar
highside107
Wow that's it? I have 22k on my Z and have even yet to hear any squeaks from my pads. Guess mostly freeway driving helps
Old Mar 12, 2006 | 06:20 PM
skeleton jack's Avatar
skeleton jack
I was hearing squeaks during my first week with my car. Everything goes to sh*t when your perfectly good brakes squeal in public. Might as well be in a beater car. Im on my way now to the brake section of this board.
Old Mar 12, 2006 | 08:36 PM
Vamos_Rafael's Avatar
Vamos_Rafael
i burnt mine within 2000 miles...
so... eh~
it all depends on how you drive
if you were to replace brake pads, check out nismo R-Tune pads...
very good none squeek pads, you can get f/r for about 240 bucks... (kind of steep) but they are definately good pads.
the only noise i got is from my rotors..
Old Mar 15, 2006 | 04:51 PM
J Ritt's Avatar
J Ritt
Mr. Pee is correct...it all depends on how you drive. Wear rates are all over the board, and can't be attributed to any single reason. Number of stops, length of stop, starting and ending speeds on stops, distance between stops, ambient air temps...they all play a role.
We find that many noise issues people have are related to not having the pads bed-in properly. Check out this article on our site:http://www.stoptech.com/tech_info/wp...contents.shtml
samansharif
Sep 25, 2015 12:31 PM
