Low brake pedal!?!?
Old Mar 15, 2006 | 01:10 PM
BeerViper's Avatar
BeerViper
Default Low brake pedal!?!?
Hey guys ... looking for some advice here ...
I picked up a set of SS Sport Lines from Grubbs and had them installed last night at GS Motosports (here in North Texas). I brought along a liter of ATE Super Blue high temp brake fluid to bleed all four OEM BREMBO calipers through after changing out the lines.
We ended up using the full liter of fluid to bleed the lines and make sure there was no air. The car stops well but the biggest thing I notice is that the pedal height is much lower than it was.
What can I do to get the pedal height back up if I'm sure there is no air in the lines? I have a track event this weekend at the Motorsport Ranch in Cresson TX which is why I wanted to get the lines and fluid done ... hopefully I don't have anything to worry about!
TIA
-Jon
Old Mar 15, 2006 | 04:47 PM
J Ritt's Avatar
J Ritt
see the other post on bleeding...sounds like there is still air in the system unfortunately.
samansharif
Sep 25, 2015 12:31 PM
