NEED ASAP RESPONSE. For those that swapped Brembos on
Old Apr 2, 2006 | 03:21 PM
D@ActiveTuning's Avatar
D@ActiveTuning
Default NEED ASAP RESPONSE. For those that swapped Brembos on
We did the brembo swap from a G35 onto a my enthusiast 350Z. We swapped the rotors, pads, calipars, and the rubber line up to the hard line.
The G35 works successfully (swapped the OEM 350Z's onto it). The 350Z is having some issues.
The Z will not hold brake pressure, we've bled the system twice, all the air is out of the line from all 4 bleeders. We started from the back, the furthest away from the master cylinder, and worked our way to the closest. There is no leaks from the calipars or from the hard lines to the rubber lines. The brake fluid is full.
When the car is off, you pump the pedal, it feels normal, you feel pressure. If you start the car, the pedal has no pressure, it feels like a dead pedal. If you pump the pedal a few times it feels like it starts to have pressure, but if you wait like 5 seconds, the pressure seems to be gone.
Anybody have any ideas what the problem is??? You help would be appreciated!
Old Apr 2, 2006 | 03:31 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
You are not supposed to use the same copper washers on the banjo bolt. If you did... try new ones?
Old Apr 2, 2006 | 03:33 PM
ht4's Avatar
ht4
I did a similar swap on my '03 touring, but did not have any problem like that you described. Possible causes:
1- You said "we've bled the system twice, all the air is out of the line from all 4 bleeders." There should be eight bleeders, not four (two on each caliper). If you did not do this already, go bleed ALL the bleed points. Start with the inside bleed point, then go to the outside bleeder on each caliper.
2- You might have air in the master cylinder... Did you let the resivior go dry at any point during the bleeding process? If this is the case, I am not sure how to address it, but it will involved bleeding the whole system out (i.e., replacing all your brake fluid). Maybe someone else could help...
Old Apr 2, 2006 | 03:40 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Also, did you try tapping the calipers with a rubber mallet to dislodge some air bubbles?
Old Apr 2, 2006 | 03:41 PM
D@ActiveTuning
I owe you lunch sometime or something lol. We just realized about the second bleeder It's too dark now, but this week we'll pull the wheels off and re-bleed. THANK YOU!
Old Apr 2, 2006 | 03:53 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Yep, I almost forgot about the backside bleeders when I did mine as well.
Old Apr 2, 2006 | 04:17 PM
ht4's Avatar
ht4
Glad I could help... Good luck.
Old Apr 2, 2006 | 11:13 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
LOL Occam's Razor at its best.
Old Apr 3, 2006 | 12:09 AM
dmoffitt's Avatar
dmoffitt
been there done that (back ones) - don't feel bad
Old Apr 6, 2006 | 04:24 PM
streetd's Avatar
streetd
wheres the best place to get the stock brembos?
Old Apr 7, 2006 | 09:46 AM
ht4's Avatar
ht4
Best place I know if is the classified ads on this board... Or the junkyard.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
