Installing New Rotors
Old Apr 10, 2006 | 09:28 AM
G3.5T's Avatar
G3.5T
Default Installing New Rotors
Is there a DIY sticky on changing the rotors on a Brembo equiped car? Looked around and searched with no results.
Old Apr 10, 2006 | 09:40 AM
suprpwr's Avatar
suprpwr
I have a feeling it's complicated
(but bump...would be interested in a DIY too)
Old Apr 10, 2006 | 10:32 AM
ht4's Avatar
ht4
It's bone simple.
1- remove wheel
2- dismount caliper (two bolts on the back)
3- slide old rotor off
4- slide new rotor on
5- replace caliper (you might want to change the pads while you have it off)
6- bleed caliper if needed
7- replace wheel
8- bed pads in per manufacturer's instructions
Old Apr 10, 2006 | 10:35 AM
suprpwr's Avatar
suprpwr
well, I mean, the instructions are simple. but arguably doing it is a bit more complicated (or maybe it's just me )
Old Apr 10, 2006 | 10:45 AM
Mike Wazowski's Avatar
Mike Wazowski
I think it might just be you
Really this is a very very simple process. About a 1 out of 5 difficulty.
Old Apr 10, 2006 | 10:52 AM
G3.5T's Avatar
G3.5T
Can anyone explain the where the 2 bolts are to remove the caliper? Also what size are they?
Why would you need to bleed the caliper?
Old Apr 10, 2006 | 11:37 AM
suprpwr's Avatar
suprpwr
doesn't this process also involve a fair amount of elbow grease (e.g. knocking the rotor off, using a clamp to depress the piston in the caliper, etc. -- things like that?)
I saw a guy do the brakework on my old Acura and it wasn't exactly something I would call intuitive. installing an exhaust/intake/etc is intuitive. this is a bit more involved.
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
