Hotchkis Sway Bars
Old May 19, 2006 | 08:28 PM
Phalocke's Avatar
Phalocke
The Immortal
Default Hotchkis Sway Bars
When I first installed my Hotchkis Sway Bars there was no audible squeaky noises. Now, about a year or so later I have this horrible squeaking when I am driving. It usually squeaks the most at bumps. Anybody know how to resolve this issue or have any suggestions? I have tried greasing the bushings but that has not fixed the problem.
Old May 19, 2006 | 10:05 PM
SponGer's Avatar
SponGer
Did you try non-lithium based grease? The instructions say you have to re-grease every 15k or once a year.
Old May 19, 2006 | 11:48 PM
mista350z's Avatar
mista350z
i dunno but that sucks man
Old May 20, 2006 | 04:39 AM
jovasi's Avatar
jovasi
Have you installed any collars on them? If not, the bars may be shifting during turns causing the noise.
Old May 20, 2006 | 07:22 AM
mario60185's Avatar
mario60185
Chicago Realtor
I have thre same issue, i have the collars too, they just need to be regreased. If i remember right they have the fittings to shoot the grease in, so its just a matter of getting under the car.
Old May 20, 2006 | 04:30 PM
SponGer's Avatar
SponGer
What sucks is only the rears have the grease fittings. You have to remove the front bushings to regrease them.
Old May 21, 2006 | 10:08 AM
mario60185's Avatar
mario60185
Chicago Realtor
Damn! I dont remember it beinbg that way. And its the fronts that need to be greased of coarse.
Old May 21, 2006 | 11:16 AM
jovasi's Avatar
jovasi
It's really not that difficult to remove the bushings.
Drive up on a set of ramps & remove the under tray. Remove the 2 brackets holding the bushings & you should be able to remove the bushings to grease them.
Old May 21, 2006 | 03:55 PM
SponGer's Avatar
SponGer
I don't know why Hotchkis didn't put fittings on the front.
Old May 21, 2006 | 04:38 PM
JDMFairlady21's Avatar
JDMFairlady21
wow.... good thing to keep in mind. slightly OT- but what settings do you guys use for your sways bars? for normal daily driving.
Old May 21, 2006 | 04:42 PM
TheCajunStyle's Avatar
TheCajunStyle
removing a away bar to regrease is as easy as an oil change.
set them to medium / medium and go from there.
Old May 21, 2006 | 04:52 PM
Phalocke's Avatar
Phalocke
The Immortal
Yeah I have the collars from McMasters, but that does not prevent the squeaking.
Old May 21, 2006 | 07:01 PM
SponGer's Avatar
SponGer
med/med for me
Old May 22, 2006 | 02:52 AM
mario60185's Avatar
mario60185
Chicago Realtor
im med med too, i kinda wanna try something new this summer though. maybe hard hard. That might be way too stiff for it though on the street.
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
