alignment after spring install.
Old May 29, 2006 | 10:12 PM
Fa1rLadyZ's Avatar
Fa1rLadyZ
Default alignment after spring install.
we'll i be able to just go into any alignment shop and get my car align to stock specs? do they have the stock specs for 350z? thank you
Old May 30, 2006 | 06:50 AM
excid182's Avatar
excid182
depends on what springs you have...if you have teins or hotchkis then it shouldn't be a problem but if you went for eibach, h&r, or tanabe then you might have some problems.
Old May 30, 2006 | 06:52 AM
fahrenheit350's Avatar
fahrenheit350
I just got mine done at Accurate Alignment in Orange.
They had the factory specs with them but I already had a copy with me when I did a search for alignment specs. Hit them up if you are in the OC area, they do a very good job.
Old May 30, 2006 | 07:00 AM
fahrenheit350
Here is the factory specs:
https://my350z.com/forum/attachment....hmentid=106219
https://my350z.com/forum/attachment....hmentid=106220
They did the best they could to get it within spec but the factory equipment can be adjust so far. So they did the best they could. I am lowered on Swifts with the rear bump stop cut. btw, I also paid $90.
Old May 30, 2006 | 07:41 AM
Fa1rLadyZ's Avatar
Fa1rLadyZ
why is that? because i have tanabe gf210
Fa1rLadyZ's Avatar
Fa1rLadyZ
this spec should be same for 06 too right?
Old May 30, 2006 | 10:27 AM
VO...'s Avatar
VO...
Administrator
I still had problems with the S-Techs. Not too bad of a problem, but alittle in the front(camber only). Rear was adjusted back to factory specs. Only the front tow could be brought back into specs.
Old May 30, 2006 | 06:07 PM
excid182's Avatar
excid182
these springs will not be able to get back into factory specs becasue the drop is much more aggressive than tein and hotchkis.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
