question for ppl with tanabe gf210
Old May 30, 2006 | 11:48 PM
Fa1rLadyZ's Avatar
Fa1rLadyZ
Default question for ppl with tanabe gf210
Did you guys had problem with putting your alignment back to stock specs? Will i need camberkit with this springs? Also if you didn't have problem putting them back to stock specs where did you get your alignment done? thank you
Old May 31, 2006 | 07:12 PM
Fa1rLadyZ's Avatar
Fa1rLadyZ
no one has gf210?
Old May 31, 2006 | 07:59 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
I have all the answers you need. Give me a call. 626-739-1922.
Old Jun 1, 2006 | 05:12 AM
n/a's Avatar
n/a
Dont buy it.. Its too soft
Old Jun 1, 2006 | 06:38 AM
Mr_Drifter's Avatar
Mr_Drifter
you are dumb
Old Jun 1, 2006 | 09:18 PM
Gsedan35's Avatar
Gsedan35
Originally Posted by Mr_Drifter
you are dumb
Well he sorta does have a point.
Tanabe GF210 Series 350Z
336/375 (progressive, softer initial rates unkown)
Stiffer then 2003/2004 oem by F+7% R+10%
IMO the bigger deal vs spliting hairs is where he's from. He may be used to typical JDM tuning, spring rates so high you might as well have solid cylinders of steel vs springs.
Old Jun 4, 2006 | 05:57 AM
n/a's Avatar
n/a
you are dumb
And this is coming from someone with the name 'Mr Drifter'....
And you are judging this from??
Your experience driving with these units daily?
If NO, then perhaps you should shut your trap.
If YES, then perhaps you are the "dumb" one.
Gsedan35,
Im commenting this based on experience with almost every Japanese Suspension including Ohlins in my cars back in Aus.
Old Jun 5, 2006 | 10:53 AM
dolemizer's Avatar
dolemizer
haha seconded. A lot of people subsribe to the notion that unbearably stiff is better. I like my GF210's, they're definitely stiff enough to make a noticable improvement in handling, but compliant enough to keep traction on less than perfect roads. Good springs + shocks FTW!
There are stiffer springs out there, but I doubt there are any aftermarket dampers (agx, d-spec, etc) that can safely handle those uber high rates short of going up to a full adj. coilover setup.
I got back within a degree, according to the alignment shop so I'm happy. A little extra camber on the rear is actually preferable for me.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
