Stoptech Stage 2 Stock Caliper Upgrade Kit
Old Jul 17, 2006 | 08:22 PM
  #41
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Originally Posted by AZNNBLK
thanks for the advice, J.. as it turn out, once the zr was lifted up, it was the front passenger rotor rubbing against the dust shield.. everything else checked out fine once the rubbing piece is removed!
Glad you got it figured out! That dust shield should be long cut off!
enjoy the kit! I loved mine!
Old Jul 17, 2006 | 08:23 PM
  #42
Jason@Performance
Performance Nissan
Originally Posted by wilric44
What is the waiting time to order this kit. Is it in stock or is there a long wait to receive order.
I believe we have a couple of kits left instock... Definatly slotted kits... drilled kits I dont know for sure..
Old Jul 18, 2006 | 09:27 PM
  #43
wilric44's Avatar
wilric44
I want the drilled rotors, since I wont be tracking my car. When you get them in let me know
Old Jul 18, 2006 | 09:53 PM
  #44
Jason@Performance
Performance Nissan
Please PM me so I can let you know tomorrow...
Best thing is to just place an order... it will be ready to ship in a couple of days if we dont have it instock...
We sell these alot...
Old Jul 23, 2006 | 08:52 PM
  #45
wilric44's Avatar
wilric44
This thought just came to my mind. I have seen other BBK o n Zs but does anyone have pictures of the Stage 2 rotors on there car?
Old Jul 24, 2006 | 07:20 AM
  #46
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Old Jul 24, 2006 | 08:23 AM
  #47
Jason@Performance
Performance Nissan
Stop tech slotted rotors... w/ NISMO Pads...
Old Jul 24, 2006 | 09:09 PM
  #48
GaryM05's Avatar
GaryM05
Originally Posted by Resolute
Robert, talk to Gary about the Ultimates. At La Junta, they will fade after twelve to fifteen laps or so, and I wouldn't recommend them for our track days. Even worse at PMI. Your best bet will be to go with a dedicated track pad and use the Ultimates on the street where they belong. The EBC RedStuff Ceramic are marginally better, and David and Gary both have had good luck with Cobalt, but both will also tell you for a good time a dedicated set of pads for the track would be your best bet. Otherwise that kit looks badass and I can't wait to help you install it As far as bedding goes, the method Z1 posted is the same I have done with all my pads and works well, just remember to not come to a complete stop while doing it and don't activate the ABS. Mike Kojiima has another method as well that I use while at the track if the pads are new, but most people don't go for it. Let me know when you want to do this and I'll be happy to come on down, or you can bring it to my place, I've got a full set of tools and a nice garage to do the work in. See ya when you're back,
Will
Wow, can't believe I missed this thread the first time around. My thoughts:
1 - The Axxis Ultimate is a good, high torque pad for the street, but it will fade at the track. It'll even fade in the full 13" StopTech BBK on a light-braking track (I tried it once at La Junta just for grins, and it faded towards the end of the day). Like Will says, I would recommend finding a good track pad to swap to for events. The Hawk Blue that's been mentioned is a good pad, but it will absolutely tear up your rotors when cold, so if you'll be swapping out at home before a track day and then driving to/from the track on the track pads, I would recommend a pad that's easier on your rotors but still has high torque...something more like the Cobalt Friction Spec VR (or even the GT Sport for lighter use). Just be aware that Cobalt Friction can take a while to fulfill orders, so you'll want to call them to place your order long before you actually need the pad in-hand. In addition to the advice from StopTech, I would also suggest you call Dave Zeckhausen (www.zeckhausen.com). I think you'll find him to be very helpful in discussing your needs and options.
2 - The biggest impact component that the StopTech Stage II kit has, in my opinion, are the lines. These are what will give you the biggest improvement in pedal feel. So even if, for some reason, you decide not to get the full kit, you'll at least want to upgrade to the lines. Just be aware that the install process for these is messy with a capital M!
3 - The Motul fluid is an excellent track fluid that will hold up nicely. However, it has been known to absorb water from the air more quickly than other fluids, which lowers it's effective boiling point more quickly. This isn't a reason not to use it, but it will require bleeding/flushing a bit more often if you find yourself relying on it frequently for heavy track use. And if you do decide to get a dedicated track pad, this is something you can do when you're swapping out the pads before a track day, so it's not that big of a deal. Plus this is great bonding time with your wife, when you have her come out to the garage to work the brake pedal as part of the process (my wife has almost got this down to a science)!
As always, good luck with your decision. Hope to see you at the track again soon! Hurry back from 'over there'.
Old Jul 24, 2006 | 11:11 PM
  #49
Robert_K's Avatar
Robert_K
Didn't Go Cheap
LOL Thanks for all this info. Think I will have a track & street pad. Might have to wait till after the UTEC install and tuned. I also like the wife/husband break bonding part. I like the way you think with that. So what pad do you recommend with the ST slotted rotors?
BTW: I should be home Mid-Sept and back at the track shortly after that!!!
Old Jul 24, 2006 | 11:28 PM
  #50
wilric44's Avatar
wilric44
Nice picture, thanks.
Old Jul 25, 2006 | 03:01 AM
  #51
Z1 Performance
Former Sponsor
Ferrodo DS2500 - far better bite, and pedal feel than the Axxis, great for track days, and won't kill your rotors.
Old Jul 27, 2006 | 04:36 AM
  #52
GaryM05's Avatar
GaryM05
The Ferodo DS2500 has a good reputation. I've never used it, but most who have seem happy with it. I tried to get my hands on some a while back, and nobody could get it to me in the time I needed. But if you tried calling around now (Zeckhausen is a great place to start), then you could probably have some waiting for you when you get back.
Other options to consider for the track are Cobalt Friction Spec VR up front and GT Sport in the back, or potentially a combination of Carbotech Panther XP 8 and 9. Between these options, I would go with the Cobalts.
One challenge when dealing with the OEM non-Brembos is the small number of pad options available…there just aren't many manufacturers that press their hard-core racing compounds in those pad shapes.
Old Jul 27, 2006 | 04:52 AM
  #53
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks for the info Gary! Don't know if I can order them before I get back. I want to get the UTEC as well. I also need to get a helmet. I just remembered! Don't think the wife is going to go for everything. We'll see.
Old Aug 19, 2006 | 05:12 AM
  #54
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Woot! Woot!! Ordered my kit last night. Hopefully my wife will be receiving it some time next week. Can't wait to see pics!!! Now I'm really excite about coming home. LOL Also since I've had some awesome offers from the great vendors here I might be able to pick up a second set of "Track" pads!!! We'll see when I return!!! Thanks for all this info everyone!!!
Old Aug 25, 2006 | 08:56 PM
  #55
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Woot! Woot! My ST Stage II Kit was deleiver!!! Waiting for the wife to send me pictures!!! Guess I need to start researching my track pads I want now. So many chooices and combos. I post pics when I get them!
Old Aug 26, 2006 | 05:34 PM
  #56
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Pics: https://my350z.com/forum/showthread....43#post2719543
Old Aug 27, 2006 | 12:47 PM
  #57
Resolute's Avatar
Resolute
Looks good man, I can't wait to smoke you at the track. At least your brakes will look good as I go by
All we need to do now is modify your suspension. Just tell Ada it's a matter of safety, or have you already used that excuse on the brakes?
Really, it looks like a good choice for your brakes, and I'd be happy to lend a hand with the install if you'd like. Tell Ada "hi" for me, and let her know the baby and Becckie are doing well. I can't wait to go on a fall drive up in the mountains and check out your car when the UTEC, brakes, and everything else is done. Should make for some good lap times too. Take it easy,
Will (very jealous)
Old Aug 27, 2006 | 05:47 PM
  #58
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Will (very jealous)
I responded here: https://my350z.com/forum/south-west/213150-got-my-stoptech-kit-pics.html
Old Sep 24, 2006 | 01:17 PM
  #59
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Got mind installed and left a short review: https://my350z.com/forum/south-west/213150-got-my-stoptech-kit-pics-2.html
Old Oct 4, 2006 | 02:06 PM
  #60
james840a's Avatar
james840a
Im thinking about getting this kit, My brakes are squiking. I have the HPS hawk pads, but sometime one or more squike when i lightly brake. This looks like a great upgrade for the price.
