Springs vs. Coilovers
Old Aug 16, 2006 | 07:05 AM
betamotorsports's Avatar
betamotorsports
If you're purchasing the T2 springs you'll also need to upgrade the shocks from OEM. Nissan Motorsprots offers a Koni double adjustable although I'm not sure which model Koni it is.
Old Aug 16, 2006 | 07:06 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
The drop is an inch. The spring rates are very high, I think theyre very similar rates as the TEIN FLEX but the T2 rates are 600 in the front and 690 in the rear. I believe in pounds the FLEX's are 690 per corner.
Old Aug 26, 2006 | 11:38 PM
Icedoutpenguin's Avatar
Icedoutpenguin
So the Koni shocks with the nismo springs would give a good streetable but stiff ride?
Old Aug 27, 2006 | 12:12 AM
Armitage's Avatar
Armitage
Whats the stock spring rates? Isn't like 440/240 or something?
Old Aug 27, 2006 | 11:00 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Your answer is in the Spring Rate Database thread
https://my350z.com/forum/brakes-and-suspension/154233-spring-rate-database.html
Originally Posted by Gsedan35
Oem springs 350Z’s 2003/2004
Front:314 Rear:342
Oem springs 350Z 2004.5/2005 (found 04 car's that have the revised susp.)
Front:314 Rear:427
Chris
Old Aug 27, 2006 | 11:23 AM
Nismo 350z's Avatar
Nismo 350z
Any links to the Koni double adj. shocks that can match with the T2 springs?
Old Aug 27, 2006 | 01:34 PM
mberthia's Avatar
mberthia
Check the TC Kline site.
http://www.tcklineracing.com/nonbmw.htm
Old Aug 27, 2006 | 09:18 PM
palepony's Avatar
palepony
to the OP - for what uses you are describing, springs with matched dampers would meet your needs.
for drag/street however, T2/TCKline would NOT be what you want.
quote sen jen - "if you're gonna boost it, run coilovers". this makes no sense, the two are unrelated.
quote 636racer - "airbags" - i would not recommend these to anyone except for very specific needs - see the airbag thread
quote betamotorsports - "IMHO, unless you're competing at the upper levels of autocross or amateur racing, coil overs won't give you anything". I couldnt agree more. A properly chosen spring rate and damper will do the job. Too many people recommend coilovers to people that will not use their abilities.
pp
Old Aug 27, 2006 | 09:27 PM
Armitage's Avatar
Armitage
pp
And this is why I'm considering running just springs and shocks. I had coilovers on my Prelude and NEVER changed the ride height.I'm considering the T2 springs mentioned above but wonder if they are too rough for street driving. But given the stock spring rate, it doesn't seem like it'd be that bad.
Old Aug 27, 2006 | 09:42 PM
palepony's Avatar
palepony
armitage
T2 springs are very roughly double the OEM spring rate in front and 1.5x in the rear.
If properly dampened, however, they might be streetable. One poster about 2 years ago reported this. The cost of revalving konis are about $110 per shock from truechoice. But definitely not the choice for the OP and his drag racing requirements.
pp
Old Aug 28, 2006 | 07:27 AM
betamotorsports
Most of the "feel" of a car on the road comes from the shock valving. Doubling the spring rate, keeping the shock compression valving around OEM levels, and increasing the rebound valving will make the ride firmer but not stiffer. I've run a 240Z with spring rates triple the OEM values on the street and because I ran double adjustable Koni 8611s the ride was fine. Passenger comments were that car was firm but not harsh and none belived I was running wheel rates over 300 lb. in.
Old Sep 2, 2006 | 08:27 AM
showbizz_41's Avatar
showbizz_41
I havent checked back in a few weeks but i opted for the JIC coilovers, being installed Friday
Old Sep 2, 2006 | 08:54 AM
ActionJackson's Avatar
ActionJackson
Do Tokico shocks & eibach springs
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
