Any Project Mu B-Force owners?
Old Aug 15, 2006 | 10:44 AM
Zexy's Avatar
Zexy
Default Any Project Mu B-Force owners?
I'm starting to be convinced that these pads are crap. I installed them and bedded them and no go on silence. The squeak real loud on me. I understand they are a more aggrressive pad but the squeak is LOUD. I don't mind a small sqeak/noise.
I knew i should have went with Endless.
Old Aug 15, 2006 | 12:10 PM
GReddySetGO's Avatar
GReddySetGO
I have Project Mu B-Force all around. Mine sqeak rarely and if/when they do, its not really loud....
How long have you had them on? Did you resurface your rotors?
Old Aug 15, 2006 | 12:28 PM
Volk350Z's Avatar
Volk350Z
Master
sixto.. did you resurface your rotor before you put the pads on?? I have the bforce on my car but ony sqeak when the pads is cold..
Old Aug 15, 2006 | 12:47 PM
SilverII's Avatar
SilverII
i have b-force front.... mine squeek sometimes. I try to ignore it.
Old Aug 15, 2006 | 03:00 PM
Zexy's Avatar
Zexy
The rotors are BRAND NEW Rotora pieces
The squeak is uber loud. My GF's dad asked me wtf was wrong with my brakes when i pulle din the house today.
Old Aug 15, 2006 | 05:25 PM
GReddySetGO
Old Aug 15, 2006 | 05:41 PM
Zexy's Avatar
Zexy
600 miles
Old Aug 15, 2006 | 07:32 PM
Volk350Z's Avatar
Volk350Z
Master
hmm that's weird.. cause i only hear mine with its cold.. where did you get the rotor/pad install?? also did you break in the rotor & pads??
Old Aug 15, 2006 | 09:03 PM
Zexy's Avatar
Zexy
I installed them myself. I broke them in braking softly for 400 miles followed by starting to get a bit more aggressive and then bedding them. The rotors look just fine. Today i went ahead and bedded them on 417 from faster speeds. After bedding and when they're warm the noise goes away but it'll most likely return.
Old Aug 15, 2006 | 09:20 PM
Volk350Z's Avatar
Volk350Z
Master
well you are suppose to do it like this at the beginning..
1) drive like 50 mph and stop hard to 10mph but dont lock up the brakes
2) do it like 5 times
3) cool down and do it again
4) but dont lock up the brakes
5) if u lock it up...the rotor might heat up too fast and u'll warp the rotor
Old Aug 16, 2006 | 06:29 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
He probably didnt bed them in properly. If you follow Volk350Z's advise I think you should be okay though you have already been driving on them for a while.
Old Aug 16, 2006 | 09:28 AM
Zexy's Avatar
Zexy
That's what i did. I found that procudure searching the forums.
How would i know if my rotors are warped? What should i look out for? I did bedding from 80-90 mph yesturday and i see slight discoloration around the middle of the rotor.
Old Aug 16, 2006 | 11:37 AM
SpeedRcr's Avatar
SpeedRcr
you can get your rotor turned to fix the warpage...most places have machines that turn the rotor while its still on the car so its cheaper labor wise
Old Aug 16, 2006 | 11:58 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Sometimes brakes are noisy. Does that make them crap? Hardly.
I'm sure a little bit of the right grease in the right spots (not on the rotor :P ) and you will have no more noise.
If you see the "discoloration at the center of the rotor" that usually means the bedding in was successful (I think!) at least, it was like that when I bedded mine in.
For the record, my axxis ultimate pads squealed really bad when I first got them on. They only squealed when I was braking lightly. This happened for like 1500-2000 miles even though they were bedded in properly. Now they are dead silent. Go figure.
Old Aug 16, 2006 | 02:03 PM
Zexy's Avatar
Zexy
Maybe you're right. I'll report back a couple of miles later... The noise is real loud though
Old Aug 16, 2006 | 02:18 PM
GReddySetGO
Yeah, I didn't break mine any using any type of break-in procedure. I just installed them and drove on them normally. I experienced some loud squeaking when they were new, cold or hot. And now I RARELY hear them squeak, and it they do, its not very loud at all, I have to have the windows down and listen for it to hear it.
I've had mine for about 10k or so now, maybe a little more in the front.
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
Dymsi
Sep 29, 2015 11:32 AM
