Operation OEM brembo upgrade...
Old Aug 23, 2006 | 08:52 PM
M3to350z's Avatar
M3to350z
Default Operation OEM brembo upgrade...
I stopped by my local junk yard and picked up a set of brembo's off a G35. It came with almost everything except rotors. So I have a set of rotors and pads and fluid on order. Anyone have any tips installing these calipers?
They look very easy except the whole bleeding line process in which i hope someone on the board will enlighten me with. The guy at the parts yard said I couldn't do it myself unless I had a special bleeding machine.
Old Aug 24, 2006 | 02:42 PM
ht4's Avatar
ht4
There is a great DIY thread on the other board about this...
Old Aug 24, 2006 | 02:50 PM
Mathys's Avatar
Mathys
Link?
Old Aug 24, 2006 | 02:51 PM
benitoz's Avatar
benitoz
wow! great find what did you have to pay for those ?
Old Aug 24, 2006 | 02:54 PM
KhanMan's Avatar
KhanMan
Yes I would also like know how much you spend as I awlays net search junk yards. And where in L.A is the closest junk yard?
Old Aug 24, 2006 | 04:27 PM
M3to350z's Avatar
M3to350z
I paid $1350 and the guy has nothing left. Yes please link me to the "other" board.
Old Aug 24, 2006 | 06:49 PM
Blue Komodo's Avatar
Blue Komodo
I'm working on this too. If I get the parts first, I'll post the info and pix for you.
Old Aug 24, 2006 | 07:00 PM
mario23's Avatar
mario23
I did the same thing then had them powdercoated red. Great mod.
The install is real easy. Just remember to cut away the dust shields behind the stock rotors to make room for the new ones. Bleeding is a simple two man job. If I were you, I would invest in some nice stainless steel brake lines while your at it. That's also an easy upgrade.
Old Aug 24, 2006 | 07:01 PM
mario23's Avatar
mario23
By the way, I found them over the phone at a junkyard in Texas. Got them shipped down to me for a steal.
Old Aug 25, 2006 | 10:40 AM
J Ritt's Avatar
J Ritt
The install manuals for our kits may help you. Obviously there are differences, but they should provide a good basic guide:
http://www.stoptech.com/tech_info/bbk_manuals.shtml
Old Aug 25, 2006 | 01:22 PM
M3to350z's Avatar
M3to350z
Excellent write up. I didn't know i need to cut the dust shield off.
Old Aug 25, 2006 | 01:24 PM
CEO350Z's Avatar
CEO350Z
That's bad juju
yeah, the shield got me the first time I swapped brakes with my friend. he drove around for a while and didnt know what that sound was. long story short, that shield's gotta get trimmed.
Old Aug 25, 2006 | 01:40 PM
M3to350z's Avatar
M3to350z
Does the shield need to be trimmed or can it just be pounded out.
Also..... Do I need a rubber hose to bleed the brake lines since the caliper's bleed fitting must be pointing up. I'm afraid that the brake fluid will eat thru the powder coat on the caliper.
Old Aug 25, 2006 | 02:33 PM
StopTech's Avatar
StopTech
Vendor - Former Vendor
You will need some sort of tube for bleeding your brakes. GO to a local auto parts store and look for a brake bleeding kit...it should have what you need.
Old Aug 25, 2006 | 03:41 PM
M3to350z's Avatar
M3to350z
Will my stock brake lines work with the oem brembo upgrade?
I appreciate your help "StopTech" even though you aren't making a sale...yet
Old Aug 25, 2006 | 06:36 PM
StopTech's Avatar
StopTech
Your stock brake lines will not work so you will need to look into that. :begin pitch: Our 350Z lines are compatible with the standard calipers as well as the Brembo calipers so you may want to look into that :end pitch:
Old Aug 25, 2006 | 06:39 PM
M3to350z's Avatar
M3to350z
How much and how fast can they get here?
Any local shops in Los Angeles I can go and pick them up?
Old Aug 25, 2006 | 08:23 PM
Wholey Smokes's Avatar
Wholey Smokes
Nice. I've got a set sitting in my garage. (I want to wait until my Volks get here and then install everything at once.
I heard that the rear mounting bolts for the non-Brembo calipers are too short and so you must buy the mounting bolts for a Brembo equipped Z. This is unconfirmed but when I went to the dealer to buy these bolts, the part number was not the same as the non-Brembo bolts.
Old Aug 25, 2006 | 08:49 PM
1nate7's Avatar
1nate7
Props for undertaking this project. I am curious though why you didn't just get a new front BBK instead. $1350 seems kind of pricey just for the calipers. Either way a huge improvement over stock and I know you will be happy with the end result.
Old Aug 26, 2006 | 05:35 PM
M3to350z's Avatar
M3to350z
Good luck to anyone that wants to steal my setup!
DIY coming up soon.
Attached Thumbnails Operation OEM brembo upgrade...-p1010288.jpg   Operation OEM brembo upgrade...-p1010287.jpg
